04-17-2013, 02:12 PM | #1 |
Has anyone ever replaced these?
My apologies I cant seem to find the proper name for this. But as you can see there is a considerable gap in between and I was thinking of cutting the rivets out and bolting them back with some grade 8 hardware.
Has anyone ever done so? Is it ok to do this? |
04-17-2013, 02:45 PM | #2 |
Re: Has anyone ever replaced these?
The are reinforcing plates to strengthen the frame.
04-17-2013, 03:08 PM | #3 |
04-17-2013, 03:23 PM | #4 | ||
"I ain't nobody, dork."
That might be like that from the factory. I'd try to confirm that and leave it alone if it were me.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
04-17-2013, 03:29 PM | #5 |
Gary, what might be there from the factory? The rivets or the plates? I'm just inquiring whether or not they can be removed, cleaned up, and bolted back together in the same locations just using grade 8 hardware
04-17-2013, 03:31 PM | #6 |
Are you referring the the gap? Looking at the truck from the rear this pic is on the right side of the frame. The gap on the left side plate is considerably smaller. That is why the question if they can be removed or not.
04-17-2013, 03:40 PM | #7 |
I would assume since others have taken other supporting members out and re bolted with grade 8 bolts. That this shouldn't be an issue
72 GMC super custom. |
04-17-2013, 03:50 PM | #8 |
The rivets? Or these particular reinforcement plates?
04-17-2013, 03:53 PM | #9 |
I've seen people completely dismantle their frame to sand blast ( thus removing rivets) then re assemble them ( using grade 8 bolts ) so I would assume if u want to remove these plates clean them and bolt them back in u could
04-17-2013, 04:17 PM | #10 |
While bolts replacing rivets are an approved repair. It is not intended that they be replaced at will. A bolt is not a direct replacement for a rivet. The holes need to be reamed to a very close fit. We are not talking the closest Harbor Freight drill bit size. Another issue is going to be bolt shank length you will need to fit the bolts so the shank is bearing the length of the holes. If its riding on the threads you are loosing strength. Review the factory service manual proceedures for the chevy version. We had a thread on this a while back if you want to search for it. But in the end I still have not found a shop level frame rivet replacement that looks and works as stock. Huck bolts are the closest to rivets for frame repairs but they are not stock appearing.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-17-2013, 04:20 PM | #11 | |
04-17-2013, 09:38 PM | #12 |
04-18-2013, 06:56 AM | #13 |
You can remove anything and "properly" bolt it back. But why,appearance? I'd move on to important things if it was my truck. Many trucks never find their way back together and worrying about things that don't matter and will never be seen,once back together,is a good way to see that happen. Don't take this personally,some go far and above what matters and still get them done and that could be you. And,often it's for other reasons that they don't get completed.
04-18-2013, 07:09 AM | #14 | |
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
04-18-2013, 07:47 AM | #15 |
if its rust build up between the two plates pushing them apart for sure knock the rivits out blast the peices an bolt'm back in.
if theres no rust between them squeeze them back together with a clamp an be done with them for these two peices that the op is asking about i dont think there is the stresses put on them that a bolt of the right size of course couldnt handle
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
