has anyone used leaf spring friction liners?
I am assembling my new rear leaf springs on my 67 and i was wondering if it would be a good idea to use some leaf spring friction liners between them? I am not going to be towing anything just a cruiser. Would this be benificial or a waste of money. Rod.
402 BIG BLOCK
Re: has anyone used leaf spring friction liners?
I got some from speedway, comes in a roll. I put on my 70 jimmy. Was a pain to put together, but turned out nice, haven't drove yet, hopefully by end of summer.
1967 C10 swb 1970 GMC Jimmy 4x4 2005 Chevy tahoe Z71 2001 Chevy impala |
Anyone else?
I replace the liners on all leaf springs. I have been using a blue plastic sheet to cut them out of using whats left of the originals for a pattern. The liners have held up well over the last 4 years.
Here is a picture of what they look like when installed new. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
I thought the liners went from one end of the leaf to the other.
I have, Just a few weeks ago. Alot quieter than before. Not to bad to do. I have enough
left to do front and rear(if you have a 4x4). Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
Junior Member
I knew a guy in the mid 1970's that put them between the springs when he built hot rods and said they made things quieter.
I had forgot about it until you mentioned it in your post. I have never tried it though.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
402 BIG BLOCK
That was how i did mine.
So my top three leaves are held together with a clamp that can't be removed and is rivited I believe. Anyone else have this? I won't be able to get liners between them. I have 7 leaves so I will be able to get the rest on. Will this matter or would it not make sense to have liners on only half the leaves?
402 BIG BLOCK
no rivit on mine, they all came apart. Anything is better than nothing, but all is best. Good luck.
