Old 04-17-2013, 04:43 PM   #1
forestb
forestb's Avatar
polyplus bushings
Should I use polyplus or rubber bushings for my trailing arms? I have heard that rubber might be better for better articulation.
forestb is offline   Reply With Quote
Old 04-17-2013, 04:55 PM   #2
1963c-10
1963c-10's Avatar
Re: polyplus bushings
Ive heard better talk about the rubber personally. Heard the poly's have to be replaced more and squeak more.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-17-2013, 05:31 PM   #3
theastronaut
theastronaut's Avatar
The trailing arms rely on the bushings to "give" to let the axle articulate without binding. Rubber is better, but if you want/need less bushing deflection then you'll want to build tubular arms with heim-style bearings to let the arms rotate smoothly without binding.
theastronaut is offline   Reply With Quote
