Old 04-17-2013, 07:05 PM   #1
crusinforty
1950 GMC Brake Pedal Help
I could really use some advise on how to mount a TCI brake pedal on our 1950 GMC. Purchased pedal assembly and the directions say to remove existing brake pedal & master cylinder and re-mount the TCI unit to the OEM frame mount. I looked at this many times and cannot determine how this can be done, none of the bolt holes line up???
Has anyone experienced this problem? If so, what is the cure and what am I missing?
Thanks!!!
crusinforty is offline   Reply With Quote
Old 04-18-2013, 01:11 AM   #2
NEWFISHER
NEWFISHER's Avatar
Re: 1950 GMC Brake Pedal Help
No experience here but when I look at mine and look at a TCI pic of one, it looks like it would mount. Where the oe master sits and the pedal curves upward through the floor. Mabey a wrong kit? Post pics of what you have and what kit you purchased.
NEWFISHER is offline   Reply With Quote
Old 04-19-2013, 09:07 PM   #3
crusinforty
Thanks New Fisher. I will try to get picture out. I did see some pictures on another post here. It looks like the person made a 1/4" steel mount that bolted to the frame in the same place as the original and then the TCI mount bolted to that.
Appreciate your reply!
Old 04-20-2013, 12:34 AM   #4
parkwood
parkwood's Avatar
This a TCI brake set up in a '51 suburban, we removed the stock M/C and bracket and installed the new bracket that came with the new M/C and booster..
Make sure you have the right M/C and booster for the right year truck.. the first one is for a '52 and the last two pictures show one for a '56 truck.. on the '56 you use the stock bracket and on the '52 you use a bolt in bracket taking out the stock one..
parkwood is offline   Reply With Quote
Old 04-22-2013, 10:00 PM   #5
crusinforty
Parkwood,
The picture tell the entire story! I got to digging around the shop and found the frame bracket. Somehow during a cleanout I put it in a spot where I wouldn't forget where it was Anyway, thanks a ton for the pictures and looks like two sweet ride you have there for sure!
Old 04-22-2013, 11:11 PM   #6
parkwood
parkwood's Avatar
Well they say a picture is worth 1000 words.. glad it helped you and becareful when you clean up...mess is best..
