04-17-2013, 07:24 PM | #1 |
computer tune and harness mods?
who the best place with a good price on programing the computer and cutting teh harness i just bought a 4.8 v-8 with harness pedals computers and accessorys and 460le trans for 1100 dollars?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-17-2013, 10:46 PM | #2 |
Re: computer tune and harness mods?
Your going to like that4.8 I run one in my 69. Revs like a 327 on steroids. I used lt1 swap and built my harness its not that hard. Sorry cant help with comp programming since I'm in Cali sure there's someone closer.
Posted via Mobile Device |
04-17-2013, 11:18 PM | #3 |
meowMEOWmeowMEOW
A dyno tune will always yield better results (and access to support) than a canned e-tune will. I dislike the concept of having to mail my computer to a tuner, especially if its for fine tuning or future minor changes. Most good dyno tuners should cover fine tuning if for example the shift points, firmness, torque managment etc needs adjustments. While some e-tuners will do small changes like that, they can only ballpark the changes, unless you go all the way to data-logging (which would then put you way past an e-tuner anyway).
04-18-2013, 01:21 AM | #4 |
Mainly I'm worried about vats And having the emission stuff turnex off then change how it RU s
04-18-2013, 03:04 AM | #5 |
Waitformeperformance has good reviews and does the harness mod and tune for $360
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
04-18-2013, 08:51 AM | #6 | |
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
04-18-2013, 09:36 AM | #7 |
I think Howell Fuel Inj. is at the top of the list for me, both , wire and computer .
I have not seen any comments neg. about them, except the cost !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
04-20-2013, 10:48 AM | #8 |
I just picked up the same 4.8l/4l60e combo for my truck. Did any one keep stock gm fuse block or you use an aftermarket one when modifying the harness?
04-20-2013, 10:52 AM | #9 |
If you mod the harness the big one under the hood goes by bye
04-20-2013, 03:57 PM | #10 |
you don't need the stock box its just a headace! most people run a 4 fuse terminal and 2 relays and just make it stand alone. then you use and aftermarket box for the rest of the truck. but if you get the aftermarket box first you can easily run the engine with it and then all wires are marked! lets face it you want to run new wires and fuses on a 40+ year old truck anyhow! you only need a hand full of wires for the truck to run tho!
04-20-2013, 11:25 PM | #11 |
This is what I used
04-21-2013, 12:26 AM | #12 |
I still haven't desicde who I want to go with for my harness mod I Dont have time to do it my self
04-21-2013, 07:23 PM | #13 |
Using the factory fuse box is Very simple & you don't have to cut the harness up, Or even take it off the engine. I will walk you through it if you want.
04-21-2013, 07:32 PM | #14 |
clinee i'd like a little more info on how to do that
04-21-2013, 08:10 PM | #15 |
You will need a "un-hacked" harness, Fuse box, Fuse box connectors, Fuse box shroud & lid. I will need the year/make/model of the donor truck to give specifics.
04-21-2013, 08:13 PM | #16 |
2004 silervado 4.8l with a 4l60e trans harness is unhacked DRIVE BY WIRE
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 04-22-2013 at 11:47 AM. |
04-22-2013, 11:42 AM | #17 |
Trying to jump on this train, sorry not trying to hijack. Mine is a 2002 4.8l 4l60e drive by cable. thanks
04-22-2013, 12:15 PM | #18 |
It looks like lt1swap.com has the break down for using the stock fuse box.
04-22-2013, 07:46 PM | #19 |
04-23-2013, 11:51 AM | #20 |
x2 on using stock fuse box, connectors. Its a little ugly and bulky, but super simple and has lots of left over relays and fuses for the other little things in life.
04-23-2013, 01:38 PM | #21 |
Do you have this info for a 2013 Camaro SS 6.2/6L80?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-23-2013, 07:37 PM | #22 |
do i even want to know how much ti cost for that motor and trans hart lool?
04-23-2013, 09:21 PM | #23 | |
04-24-2013, 01:08 PM | #24 |
I've chopped up a few harnesses in the past.
This go-round I spent the $ to have it done professionally. I had Bill @ BP Automotive do mine and he did a fantastic job. $350 and it came back looking great. He's a sponsor on ls1tech.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
04-24-2013, 01:14 PM | #25 |
Cline I thank you for the help I was suppose to get the fuse box but they sold the fuse box out of it before I picked up the motor so all I got was an in uncut harness
