different brake lines with drop spindles?
so, i just ordered the cpp modular drop spindles and brackets for my 70 gmc. it already has shorter coils on the front, and has been swapped over to 73-87 a-arms and disc parts.
im not sure my brake lines will be long enough to reach once it comes down 2" more(could have used 3" but needed the narrowed track more then the extra inch...) i thought i read somewhere about maybe the 3/4 tons having a longer brake line, or maybe it was the 4x4's? guess im trying to get ahead of the game and have my plan in place if i decide they wont reach since im wanting it together for a trip in a couple weeks... |
![]() Join Date: Dec 2012
Re: different brake lines with drop spindles?
The lines on my new disc brake front, 3/4 ton standard height, are pretty long. If you'd like I can put a string against and measure for you.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#3 | |
they are saying a 10mm assuming it really is correct for the 73-87 style front suspension under it. and giving me dimensions of 20-21" length for the line. i took a rough measurement of mine(tape quick this morning) and even following a few bends with the tape it is nowhere near that. we are talking maybe 14-15? i may need them to be a bit longer, but that may be excessive... |
