06-21-2003, 08:14 PM | #1 |
WTB 81-87 swb 4x4 frame
Anyone have one in or around Ohio?
70-Olds 442 66-Impala 4-dr. 67-K-10 87 Chev. 1/2 Ton 4x4 Swb |
06-22-2003, 04:39 AM | #2 |
I know of one here in MO. Just about bought it myself. 79 short 4x4 with a running 350, tranny, and a 205 I believe. Frame actually looks pretty good if cleaned up and painted. He's wanting a 1000 bucks.
06-22-2003, 09:19 PM | #3 |
Thanks for the reply Mudder, would like to find one a little closer and just in need of a bare frame. Thanks
06-24-2003, 11:20 PM | #4 |
Too bad your not closer i've got one i would give ya just to get it outta the way.
EXPERIMENTAL STAGES OF SANITY _____________________________ Run whatcha brung, and hope you brung enuff |
06-25-2003, 08:27 AM | #5 |
Thanks Trukkers69, I've seen a few up here and like mine they are bad in the same spot, right in front of the rear spring shackle behind the gas tank, drivers side? Might have to end up pacthing mine up. Must be an Ohio thing.
Also noticed you had 292 in the truck you sold? How did you like that motor? I'm still trying to decide wheather to run mine or not in my 67K-10.
06-25-2003, 08:19 PM | #6 |
If i were you i would run the 292 .It had plenty of power (for me anyways ) and would run when nothing else in the yard would. If i had it to do over again i would have kept the truck and fixed it instead of my 67.
06-25-2003, 10:41 PM | #7 |
king $h!t
i have hole truckswb 4x4 gmc runs great needs some worki will sell u for 4500 obo then u wouldnt need a frame
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s |
