Old 04-17-2013, 10:47 PM   #1
coyotes33
coyotes33's Avatar
cant catch a break!!
So I still have the knocking sound in my 5.3. The seller won't answer my calls and hangs up when I call from a different number. Today was the second time I took the truck out for a drive to see if it helps the lifters. Once I got back I left it out there for about an hour and went back out to move it. It started with no problems but when I put in gear it stumbles and shuts off. Any ideas? Could it actually be my torque converter or flex plate and that could be the knocking sound?
Here is an updated video with the exhaust hooked up
https://www.youtube.com/watch?v=Vb3B...e_gdata_player
coyotes33 is offline   Reply With Quote
Old 04-17-2013, 11:12 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: cant catch a break!!
Well if the seller made some sort of warranty, I'd show up at his house and "persuade" him again...but if its some joe off craigslist, not much you can do.
If you have access to someone with an advanced scanner (not just a code reader) you can monitor knock and see if its actually "knock" or a "tick" from the valvetrain or elsewhere. It almost sounds like the cold-start piston slap that the early 5.3's were known for, but that usually went away after a few minutes.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-17-2013, 11:47 PM   #3
coyotes33
coyotes33's Avatar
It was from cragslist and he has several listing. The knocking wouldn't go away, the truck would shake whenever I would stop and going uphill.,
Old 04-18-2013, 12:06 AM   #4
Kim57
Kim57's Avatar
The first thing I would do is pull the rocker covers and see how it all looks.
They're pretty easy to get once the coil packs are removed.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-18-2013, 01:07 AM   #5
Critter
Future TOTM Winner
Critter's Avatar
Do you have any idea of the mileage on the motor when you got it? From the video (and my laptop speakers) I initially think it's the torque converter/flexplate. But stumbling and dying when you put it in gear isn't a flexplate problem, it would keep running. That's either the torque converter or something on the input area of the trans OR its an unrelated problem that doesn't have anything to do with that ticking. Just trying to think out loud...
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 04-18-2013, 03:19 AM   #6
BigDan3131
BigDan3131's Avatar
That sounds like a rocker hitting the valve cover or a torque convertor bolt hitting something underneath. It doesn't sound like a lobe/lobes gone flat that sounds different, this is more tinny.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 04-18-2013, 08:41 AM   #7
whitels1
whitels1's Avatar
It sounds like it's in the valve train, pop the valve covers off and take a look, check all the pushrods and rockers and go from there.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 04-18-2013, 09:29 AM   #8
coyotes33
coyotes33's Avatar
It has 90k, I pulled the the covers a couple of days ago. Made sure the rods were straight and not clogged, rockers look good as well. I can also hear/feel the knocking close to the transmission. I'm guessing the gears are jamming up and causing the truck to shut off.
Old 04-18-2013, 12:08 PM   #9
eagleuh1
eagleuh1's Avatar
Do you have all the wiring hooked up right for the torque converter lockup and unlock. You should have the correct brake pedal switch that has a wire for the torque converter unlock. When brake applied, torque converter unlocks. I would check that if its only doing it when idling and stopped. Just listened to video. That does sound like something in the engine though.
eagleuh1 is offline   Reply With Quote
Old 04-18-2013, 12:12 PM   #10
coyotes33
coyotes33's Avatar
I'll check the tcc switch but I drove it fine twice before it went to s**t.
Old 04-18-2013, 01:10 PM   #11
tinydb84
tinydb84's Avatar
I recently had an issue with a buy off craigslist where the guy was completely ignoring me. I emailed him his home address (he didnt know I had it because we met somewhere else). He responded right away and made good on a return. Sometimes you have to be an asshole. Or small claims court!
David
Instagram: myfabguy
Old 04-18-2013, 01:16 PM   #12
coyotes33
coyotes33's Avatar
That's what we did, met up at a store then took me to the lot where he has all his trucks. I dont know if I can do the small court thing since he didn't put anything regarding the warranty but at the same thing he didn't write down it didn't have one.
Old 04-18-2013, 02:38 PM   #13
Critter
Future TOTM Winner
Critter's Avatar
Unfortunately, I don't think any warranty is implied or inferred off of a craigslist purchase. It's buyer beware and pretty much any court would see it that way UNLESS there was something in writing. As far as the drivetrain problem eagleuh1 might be on to something. When we run cars on the dyno with a lock-up converter switch on the dash, if it gets left on when the dyno brake is turned on, it will pull the vehicle down and kill it, that goes for 800 ft*lb diesels as well. I know you said it drove fine for a time, maybe a wire came loose or is shorted out etc keeping the converter locked???
Old 04-18-2013, 04:54 PM   #14
tinydb84
tinydb84's Avatar
Sometimes a threat of small claims court is enough. I would start with posting a bad review on yelp/google/etc and let him know you will continue to do so until he resolves the situation.
My issue with a craigslist sale was for 200 bucks and I did my best to make the dude suffer based on principle hahah
David
Instagram: myfabguy
Old 04-18-2013, 04:59 PM   #15
coyotes33
coyotes33's Avatar
Yeah I posted a "Beware" post and he finally answered today and kept saying that I probably did something to it or dropped something in there and i could take him to court if i wanted...etc
Old 04-18-2013, 08:47 PM   #16
coyotes33
coyotes33's Avatar
So I checked all my connections and the wires from one of the clips to the injectors came off. Put them back and I was able to drive it but it still stumbles when a gear kicks in. Took it to a tranny shop and he said it does sound like my converter but can't really look into it until Wednesday. on my way back I lost my gears I had to slow down to 15mph so first could kick in. If I gave it gas I would loose it, so it should be the converter??
Old 04-19-2013, 12:03 AM   #17
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
This is a little more worst case scenario but you could have splines broken off of one of the internal gears of shafts on the tranny. Kinda like someone liked to do reverse and nuetral drops and ate the teeth off. Thats assuming that you can kinda "Feel" all this in the car when your driving.
You got metal in the trans pan? Does it still make the same noise in nuetral as it does in park etc? Each gear always the same noise?
Old 04-19-2013, 02:41 AM   #18
chebyshortbox65
chebyshortbox65's Avatar
Which trans are you using? Sure the tourqe converter is not pushed through the pump from not being all the way in while being installed?
chebyshortbox65 is offline   Reply With Quote
Old 04-19-2013, 09:14 AM   #19
coyotes33
coyotes33's Avatar
i'm going to drop the pan today and check. It does sound the same in every gear.
I'm using the 4L60E, I never took it part. Just how i got it i installed it, since the seller asked me not to open anything up incase there was something wrong.
The bastard called me at 2:30am, i wonder if he was drunk and pissed off because i told him i was going to take him to court or maybe he saw my post on CL.
Old 04-19-2013, 07:40 PM   #20
coyotes33
coyotes33's Avatar
Here is another video. The sound changes when I put in R and D. I was able to check the bolts on the TC and they are good.
https://www.youtube.com/watch?v=6GfV...e_gdata_player
Old 04-19-2013, 09:35 PM   #21
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Did you smack the flexplate and see if it rang? Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
