Old 06-21-2003, 08:43 PM   #1
70cst10
HELP!! LT1 runs great, but won't start!
Hi. I finally got the lt1 in my truck fired up today. The only problem is, it won't start without some starting fluid in the intake. It runs great after that. It idles perfect and roars like a beast with throttle. What could the problem be? It seems like the injectors don't turn on until after the motor starts. I don't know where to look for this..
Milan
1964 Chevelle SS 283/M20
70cst10 is offline   Reply With Quote
Old 06-21-2003, 09:00 PM   #2
krue
Designated A-hole!
krue's Avatar
Make sure your fuel pump is starting as soon as you turn the key on. Other than that I can't help.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-21-2003, 09:06 PM   #3
cableguy0
really dumb question and i dont mean to insult you but are you a running a mechanical or an electric fuel pump. but other than that if the pump is electric like it has to be make sure it is wired to have power when the key is on not just after the engine is running. did u use the stock harness get a custom modify it or what? the more info u can give the more we can help ya
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-21-2003, 09:10 PM   #4
70cst10
I've got the camaro pump (electric) in a new aluminum fuel cell. It pu,ps fine and primes the system when the key comes on. It just won't fire without starting fluid. I don't get it. Could it have something to do with the brake switch? I didn't use the switch from the camaro, and I noticed it powers the pcm for something..
Milan
Old 06-21-2003, 09:48 PM   #5
Project1970
14.1 @ 96MPH
Project1970's Avatar
I don't think so...
I don't know enough of the LT1 off the top of my head to remember if there's any sort of cold-start injector or anything. It sounds like whatever is supposed to prime it is just not doing its job. Try some Camaro or Corvette boards...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 06-21-2003, 10:07 PM   #6
68 Stepside
huh?
68 Stepside's Avatar
The 97 T/A we had in auto shop had a similar problem. We had to put our hand over the air inlet to start it after it had been sitting for about a year not running. After we ran it for a while, the problem went away, but I can't guarantee it'll help you out....just something to think about.
Good luck, and keep us posted.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 06-21-2003, 10:12 PM   #7
Mike C
Mike C's Avatar
Make sure that the fuel pump and ignition are both getting 12v DURING cranking. I had a crappy Accel electronic ignition that would only fire when you let off the key from cranking. Dumped that POS.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-21-2003, 10:26 PM   #8
ddsmith
Glowing since 1978
ddsmith's Avatar
I vote for a cold start injector. It is suppose to inject gas for startup only. If it is not functioning then you would experience this type of problem.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 06-22-2003, 03:25 AM   #9
jay-dawg
chevelito
jay-dawg's Avatar
Congratulations, glad to hear you are in the final stages of your engine swap. Hope the problem clears. BTW, which company did you go with for your gas tank.
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 06-22-2003, 03:43 AM   #10
sgtjed
What if?
sgtjed's Avatar
might ask these guys here under the hybrid part of the forums.
http://lt1tech.com/
2002 red extended cab Silverado
2002 Wheatland yellow Suburban
sgtjed is offline   Reply With Quote
Old 06-22-2003, 11:26 AM   #11
jay-dawg
chevelito
jay-dawg's Avatar
linky no worky.
Old 06-22-2003, 11:45 AM   #12
Smooth68
Smooth68's Avatar
looks to be correct link, site just appears to be down.
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 06-22-2003, 12:28 PM   #13
70cst10
I had a friend make the tank for me. He did an awesome job and didn't charge me anything.
I'll try covering up the air intake and see if that helps. Another thing I noticed is the fuel pump is only pumping about 35psi. I have a manual that says it should be regulated between 41 and 47psi. Could this be the problem? I don't get why the motor runs so great, but won't start. It seems like it's getting enough fuel running.
Milan
Old 06-22-2003, 12:57 PM   #14
Project1970
14.1 @ 96MPH
I believe 35 is low...it's definitely a fuel delivery problem of some sort, and that probably isn't helping. I'd also look into the possibility of a clogged injector...I did a bit of research and it looks like LT1's don't have a cold start injector (tuned-ports got rid of them in 1989 or so).
Did you run a new feed line from the tank to the engine? I believe the stock line is only appropriate for a return and can't cut it for feed...
Old 06-22-2003, 02:22 PM   #15
70cst10
Well, we got it running. It turns out, the direction of air flow through the MAF is pretty important. duh... It runs awesome now, and it fires up on the first or second turn (hot or cold). There's still a bit of small stuff that needs to be finished. I'll probably be driving it next weekend.
Milan
Old 06-22-2003, 03:06 PM   #16
sgtjed
What if?
sgtjed's Avatar
cool ya got it fixed,the website i posted is down at the moment it seems,but they have some good stuff there.
Old 06-22-2003, 07:38 PM   #17
Blackhawkdc
440 american Horses
Blackhawkdc's Avatar
check your fuel pressure regulator
Seth Petro
1969 Chev Short Step
425hp 350, TH400, big tires, fast truck
1979 Pontiac Trans Am
1991 Saturn SL1 - gas mileage! (and free)
1977 Buick LeSabre - for sale
May America bless God, and may God bless America
Blackhawkdc is offline   Reply With Quote
