Old 04-18-2013, 09:52 AM   #1
rs74
rs74's Avatar
Have a few questions- trying to plan ahead.
Hey guys, I have an 85 short bed that I am rebuilding. My goal when it is time is to put an LS engine in it. I have to call about a 6.0l from an 05 GTO today. My question is how are some of you running your fuel system with dual tanks. I bought new tanks thinking I was going to run a 355 which I may have to for awhile. I know this has been discussed but I can not find a good thread on this.
If I get to put in an LS then I like to keep both tanks since they are new and don't want to put in a blazer tank. The tanks I bought don't have the baffles in them like the 87 tanks do. Will that be an issue. How is the fuel pump run or do you run dual pumps and still use the tank transfer switch to power the pumps or what. Not quite sure how this would work. I would like to look into this now so I will know what I am up against if and when it becomes reality for me.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-18-2013, 09:57 AM   #2
thump16
thump16's Avatar
Smile Re: Have a few questions- trying to plan ahead.
www.hotrodlane.cc has two squarebody swaps a 77 with a ls1 swap and a 85 with a ls2 from a gto. They are both running dual tanks. you dont have to buy their parts but they have good info on the swaps.
you will need baffled tanks.
There is also alot of info on this site just use the search function.
thump16 is offline   Reply With Quote
Old 04-18-2013, 10:55 AM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
Baffled tanks are a must if you ever plan to run it hard below 1/3 tank.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 04-18-2013, 10:57 AM   #4
bohmankid
bohmankid's Avatar
You dont actually NEED bafed tanks, just make sure you keep the fuel level above half and the sloshing wont starve the pump.
You'll need to run dual pumps. I'd go with in tank pumps. My in-tank fuel pump for my ls swap cost me $20 bucks and it was the easiest thing to wire up. We'll see how long it lasts.
Also, make sure your fuel tank selector valve can handle the high pressure running through it. I've seen the high pressure ones, I just forgot where. On the side of my selector valve, it says it can handle 'up to 60 psi'. I don't think you'd wanna chance it with that stock valve.
OR, you could just use one tank and ditch the selector valve. You'd have an extra tank for the future, or sell it.
I've been watching your build thread. Cool job.
bohmankid is offline   Reply With Quote
Old 04-18-2013, 11:07 AM   #5
rs74
rs74's Avatar
I just called about the GTO. The guy said between $5-6000 for everything. Engine, trans, wiring, relay boxes, computer, trans module, all accesories. gas pedal and sensor. I seen on the link provided above where they said to switch the selector valve to a higher pressure one. Just trying to see what all I would need to do the swap. Now would be the time since the body is off. I have a couple of small blocks to put in it but ultimately the build is to have an LS or Vortec in it. If I put a FI engine in it then I probably won't be getting the whole truck painted. Not sure if I am liking the sound of that or not.
Bohmankid, thanks for the kind words. Not really a whole lot has been done except for the frame. Still a long ways to go. A little here and a little there.
Roy
1987 R10 shortie
Old 04-19-2013, 09:27 PM   #6
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
I have 87 tanks with walbros inside and the 87 TBI electric valve on mine. I did isolate the dash switch from the pumps with a relay, it was overloading that section of switch. Nearly 12k miles now. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 04-20-2013, 12:11 PM   #7
jorgensensc
jorgensensc's Avatar
Just my .02 here. Can't help you with the tank situation, but that price seems high, even for a 6.0 from a GTO. For reference I bought an 08 6.2 with 6 speed auto (48k miles) and everything needed from the donor vehicle ( computer, maf, pedal, accessories, harness, radiator, fans, driveshaft, fuel lines, tranny lines, in tank fuel pump, etc) for 5500.00. That's here in California. I didn't get a smoking deal, but what I thought was a fair deal. I couldn't find any smoking deals that some of these other guys find. Like I said, just my .02.
Good luck!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
