Old 04-18-2013, 02:15 PM   #1
85burb
85burb's Avatar
p0332/p0300
I am getting p0332/p0300 just about everytime i get on the motor hard. Could this be my ecm just needs a good tune. the p0332 is knock sensor 2 bank 2 and p0300 is random missfire code. I have a 6.0 with cam and headers and cold air intake. If i drive it normal i dont get codes. If i get on it they come up. The ecm has a factory tune in it now except for the normal swap stuff. Thanks for the help
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 04-18-2013, 03:11 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: p0332/p0300
Sounds like it could be an issue with the misfire counter being set to tightly. If the cam is on a low LSA and is really lumpy, it can cause a problem with the misfire count and cause the ecm to do things like pull the truck out of lock up, as well as some stumbling/bogging on decel etc. A tuner should be able to make some small adjustments and iron it out...I had a similar problem last summer.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-18-2013, 03:17 PM   #3
85burb
85burb's Avatar
Re: p0332/p0300
Cam specs are in my sig. It also hesitates when I make large fast Throttle changes. Like punching it off a stop. Some times it pops then takes off.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-18-2013, 03:32 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: p0332/p0300
how is it tuned? just a stock tune w/VATS disabled? if so...I'd say you need an update.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-18-2013, 03:35 PM   #5
85burb
85burb's Avatar
Re: p0332/p0300
Ya it is a factory tune with vats and emissions crap removed. I have found a place to get a tune so in a few weeks I should have the money for the tune. Then I will know for sure. I have read that a miss can cause the knock sensor codes.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-19-2013, 12:17 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: p0332/p0300
Based on that cam, you should DEF be running a modified tune, your probably falling flat in a number of areas on a stock tune with that came and long tubes. The computer would be working overtime to keep it happy.
The misfire detection in the pcm can be "desensetized" a little, allowing for a higher rate of misfire before triggering the actual pcm code (aka the flashing CEL you'd get on a normal car). There are a couple things he can do; but do NOT let him just switch misfire detection off. Guys will double the temp values to weed out the false misfires, in some cases with big cams guys will max out the value (32000) in all the cells and it prevents the codes, while technically leaving misfire count active.
Old 04-19-2013, 08:26 AM   #7
85burb
85burb's Avatar
Re: p0332/p0300
It runs ok but for sure is flat in lots of areas. Seems like anything over 1/8 throttle is lacking. Talked to the tuner and he thinks I am way lean and pretty much told me to baby it to him. Next weekend or so I should be able to get it there.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
