Old 04-18-2013, 07:16 PM   #1
debbieandmark
factory tach and HEI
is it possible to run a later HEI with a msd 6a and the factory tach.
Thanks in advance
debbieandmark is offline   Reply With Quote
Old 04-19-2013, 10:47 AM   #2
Brad54
Brad54's Avatar
Re: factory tach and HEI
Usually no, early tachs can not be used with modern electronic ignitions.
AutoInstruments in Virginia can convert them to work with HEI.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 04-20-2013, 10:18 AM   #3
chevyrestoguy
chevyrestoguy's Avatar
There is definitely differing opinions on this:
http://67-72chevytrucks.com/vboard/s...d.php?t=518458
If it were me, and because you're running a MSD 6A, I would put an in-line filter in just for added protection and I am one who believes that it provides a better, more accurate signal, to the tach.
When GM came out with the HEI in the mid-70s, even they figured that a filter was necessary. All of the GM cars with HEI and a factory tach had filters. You can find this filter on ebay for pretty cheap.
Here's an example of what a used one looks like:
http://www.ebay.com/itm/82-83-84-85-...3e38f9&vxp=mtr
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-12-2013, 08:57 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Anymore info on this topic?
66 C20 Service Truck:
Old 12-12-2013, 09:14 PM   #5
Irishbleueyes
Thanks in advance
Off topic, how well does the MSD work with the HEI? Does it clean up the exhaust at idle?
Irishbleueyes is offline   Reply With Quote
