key switch/ignition
Ok to start out i got this truck from a friend and it was running when i got it...i started tinkering and i went to start it and nothing happened when i turned the keys...i pulled the starter off and crossed the hot wire over to the start terminal and it engaged,is this a key switch problem? Or bad solenoid? Ps how do you get the key switch out to change it,i broke that looking for the problem
Posted via Mobile Device |
Re: key switch/ignition
turn the key full left to ACCY, insert object into hole depressing pin. turn key& cylinder left and pull out. To remove ignition switch from dash unscrew bezel, unhook electrical from the back and then remove.
How does the bezzel come off?
You have to take the tumbler out as mentioned above, the the bezel just unscrews.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
72 GMC super custom. ![]() |
Any special way to unscrew the bezel because mine wont budge
If you have the tumbler part out then u can maybe use a flat head screwdriver in the notches on the bezel with some tapping of a hammer counter clockwise to get it started
That worked with half swing of the hammer just very Tight......anyone know about the original problem?
I know another guy had some wires come loose in the ignition. Just wore out?
Will find out i guess...im replacing starter and key switch assembly tomorrow, there is however a black wire coming off the fuse box that has an inline fuse that was blown but the wire was not hooked up,its labeled on the fuse panel as ignition but i have no clue where it goes
The black wire with the inline fuse coming from the ignition spot on the fuse panel....where does it go that is my highest suspicion
#13 |
Maybe someone else will chime in. I would just follow it and find out
#14 |
Your help is appreciated thanks a ton....when i get some time ill follow the wire off the start terminal on the solenoid and see where it goes because it isn't getting power i guess
#15 |
Could very well be it
