Old 04-18-2013, 09:26 PM   #1
Snowbound
Snowbound's Avatar
Factory GM Serpentine Setup Help
Gents,
I mounted a serpentine set up with AC delete to my '65. I'm a little lost as to what upper hose to use. The factory 65 hose interferes with the alternator.
I'm running the stock HD radiator with 1.75" inlet/outlet.
I'm hoping to not have to use a flexy hose! Any help?
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 04-18-2013, 09:48 PM   #2
Reyals Bemus
Re: Factory GM Serpentine Setup Help
I am running the GM serpentine setup as well. It is a great system! Very well engineered and light-years ahead of the old V-belt systems. I really like it. I too had interference issues with the upper rad. hose. What I did was go down to the parts store and dig through the various hoses they have hanging on the racks. I found one that was the right diameter and had bends that seemed like would fit. Bought it, lined it up, cut it, and bolted it right in.
Reyals Bemus is offline   Reply With Quote
Old 04-18-2013, 09:58 PM   #3
Snowbound
Snowbound's Avatar
Don't suppose you have the number off it? Nobody has much stock of anything here.
Old 04-18-2013, 10:51 PM   #4
chevyrestoguy
chevyrestoguy's Avatar
I'm all ears on this one. I'm using a serpentine system from a 1990 half-ton truck. I was planning on bending up a tube like the V-8 trucks had and using the small 4" hose sections on each end.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 04-18-2013, 10:52 PM   #5
DPowers
DPowers's Avatar
Thought about going to your local muffler shop and having them bend you a piece of alumanized exhaust material?
DPowers is offline   Reply With Quote
Old 04-18-2013, 11:45 PM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
This is what I did. It is a BB but pretty much the same. I had to get a thermostat housing from a van which pointed straight up and I also needed it to be threaded so I could put a return line for the heater on it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-18-2013, 11:50 PM   #7
doobiebro
doobiebro's Avatar
What I did on mine is I went to the local parts store and went through all the (gates) flex hoses and found the correct length (upper and lower hoses)...sorry cant find the part #s... I ordered a chevy 45 degree rotating water neck thermostat housing swivel style on ebay (Whites Performance) with shipping under $15.00..here sum pics...
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 06-05-2013, 12:27 PM   #8
dallas71
dallas71's Avatar
all, how did you run the alternator wiring with this setup? i currently have the old alternator running the one wire setup, any help would be grateful
dallas71 is offline   Reply With Quote
Old 06-07-2013, 09:57 AM   #9
kieth
kieth's Avatar
Originally Posted by snowbound View Post
gents,
i mounted a serpentine set up with ac delete to my '65. I'm a little lost as to what upper hose to use. The factory 65 hose interferes with the alternator.
I'm running the stock hd radiator with 1.75" inlet/outlet.
posted via mobile device
we took a coat hanger and bent it to the correct shape, noted the diameters, then went to the parts store and went to the back wall and found the hose we needed. Took about 30 minutes...
kieth is offline   Reply With Quote
Old 06-07-2013, 11:26 AM   #10
61K10
61K10's Avatar
please post part# if you have them---
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-07-2013, 11:39 AM   #11
jayoldschool
Moderator
The stat housing from the 91-93 Roadmaster/Caprice might help. It points backwards to clear the hose around the accessories.
jayoldschool is offline   Reply With Quote
Old 06-07-2013, 01:30 PM   #12
doobiebro
doobiebro's Avatar
Are you using the old alternator on the newer mounting brackets? Depending on which wiring harness - OEM or newer (upgrade) you are using here is a helpful link. I went with newer alt and a new aftermarket harness from AAW. Hope this helps... http://www.americanautowire.com/PDFL...20IN%204.0.pdf
Old 06-07-2013, 05:56 PM   #13
dallas71
dallas71's Avatar
Thanks doobiebro
