Old 04-19-2013, 12:30 AM   #1
wraprail
wraprail's Avatar
81-87 Grille trim
Wandering through the wrecking yard today I came across this trim I have never seen before. Anyone know what or where this is and where I can get me some?
wraprail is offline   Reply With Quote
Old 04-19-2013, 12:49 AM   #2
1981Stepside
1981Stepside's Avatar
Re: 81-87 Grille trim
didn't all 81-87's have that? LMC sells the trim - page 40
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 04-19-2013, 02:05 AM   #3
83GMCK2500
That is quite unlike what is on my '83. That might be 88+, even 90-91.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 04-19-2013, 07:17 AM   #4
wraprail
wraprail's Avatar
I'm thinking 88-91 used a plastic grille and the outer trim is part of the grille.
This is stainless steel and smooth with no detail. And the truck it's on is around an 81-83
I never seen it before.
Old 04-19-2013, 07:21 AM   #5
wraprail
wraprail's Avatar
I didn't see any trim on page 40. Only patch panels and fenders
Old 04-19-2013, 07:45 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
hmm my 87 and 88 had a ridge in it
looks like quad lights tho
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-19-2013, 08:40 AM   #7
Izedabye
Izedabye's Avatar
They are exactly the same as my '81 Sierra Classic. Corner are square on the top and rounded on the bottom.
Izedabye is offline   Reply With Quote
Old 04-19-2013, 09:18 AM   #8
1981Stepside
http://www.lmctruck.com/icatalog/cc/t.aspx?Page=40
Old 04-19-2013, 09:30 AM   #9
wraprail
wraprail's Avatar
Let me explain with a little more detail, this trim is smooth and rounded over. Does not have the ridge detail as the "normal" 81-87 trim this trim is wide and low profile. . Look closely at the photos
Old 04-19-2013, 10:34 AM   #10
Keith Seymore
Keith Seymore's Avatar
Yes - I believe that is for 88-91.
The wheel opening trim is smoothed over as well (which I had never noticed before but was pointed out to me on this board).
If you wanted some like it why didn't you grab it off the truck in the yard while you were there?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-19-2013, 11:11 AM   #11
wraprail
wraprail's Avatar
I may go back and see if I can salvage it. It's really hammered in a few spots.
Isn't the 88-91 trim plastic and part of the grille ( as one piece?)
Old 04-19-2013, 11:57 AM   #12
Keith Seymore
Uh - I'm not sure, now that you mention it....
K
1979-1986
1986 - 2019
Old 04-19-2013, 01:35 PM   #13
AntiGov
AntiGov's Avatar
could it be earlier ? my 84 and 88 both have the one with the ridge.....my brother had an 81 crew with this smooth trim I believe
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 04-19-2013, 02:18 PM   #14
mooseknuckles
mooseknuckles's Avatar
never seen it smoothed off like that?...my 86 has a ridge in it....you should of snagged it up....
mooseknuckles is offline   Reply With Quote
Old 04-19-2013, 03:01 PM   #15
1981Stepside
It must be. My 81 has the same trim. I thought all years had the same. Guess not.
Old 04-19-2013, 06:01 PM   #16
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
81-82 Style, smooth
83-87, 88 has the groove
SamsAutoParts73-87 is offline   Reply With Quote
Old 04-21-2013, 01:34 AM   #17
81Scottsdale520
81Scottsdale520's Avatar
same??? my 81
~When In Doubt Go Lower~
81Scottsdale520 is offline   Reply With Quote
Old 04-21-2013, 01:42 AM   #18
Outlaw87
Outlaw87's Avatar
Originally Posted by SamsAutoParts73-87 View Post
81-82 Style, smooth
Correct. That is the 81-82 trim. 83-88 had the trim with the grove/ridge, the more common one.
Outlaw87 is offline   Reply With Quote
Old 04-21-2013, 08:41 AM   #19
motornut
78K & 79C Jimmys
motornut's Avatar
this 81 i looked at has it too,drilled for winter cover....
John
Old 04-22-2013, 12:40 PM   #20
silvereagle07
silvereagle07's Avatar
Yep that's the same trim my 81 had.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 04-22-2013, 01:14 PM   #21
aggie91
I'm just glad to be here!
aggie91's Avatar
Yep. That trim is 81-82 Only trim. Same as my 82.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-22-2013, 01:18 PM   #22
aggie91
aggie91's Avatar
Crap. Double post.
Karl
The LST Challenge:
