Old 04-19-2013, 03:05 PM   #1
Longhorn 70
Longhorn 70's Avatar
BOAT cam in a truck? Opinions please.
I have been looking to replace the tired 425 Olds in my 3/4 ton. One of the rods is making a noise and telling the others that he is longer than them. I like the Olds power, economy and reliability not to mention the truck is already set up for Olds.
I have found a replacement Olds engine for a reasonable price. It was built for a jet boat though. I don't really know much about the boat cams except they are used in apps that turn 4500 r.p.m. for extended periods of time and make good vacuum down low. Would/could this be good in a truck app???
Should I just go back to the small block Chevy and be done with it??
Thanks in advance for all opinions.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 04-19-2013, 04:32 PM   #2
wibilly
wibilly's Avatar
Re: BOAT cam in a truck? Opinions please.
it's just right if you frequently run your truck at 4500 rpms if you don't then it isn't what you want
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 04-19-2013, 04:49 PM   #3
budman k20
1972 K20
Boat cams run very little overlap (intake and exhaust valves open at the same time) due to them having water cooled exhaust. Would be close to a stock non performance cam and probably make good torque which I think is good for a DD truck.
budman k20 is offline   Reply With Quote
Old 04-19-2013, 07:21 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
Lobe seperation 112* comp xm278h the most extreme cam I could find for water cooled manifolds.
One thing to remember A LOT of jet boats don't have water cooled exhaust manifolds and all bets are off on what kind of cam might have been used.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-19-2013, 08:17 PM   #5
cdowns
cdowns's Avatar
if the olds engine is cheap enough they do still sell camshafts for old olds engines
Old 04-19-2013, 08:18 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
Answered your own question? Have it rebuilt. If you buy a 350 crate engine, then all the accessories, intake, carb, dizzy, and everything else you would need, you'll have $3000 to$ 3500 in the swap.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-19-2013, 09:05 PM   #7
Mustard72
Mustard72's Avatar
There's no replacement for displacement.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 04-19-2013, 09:10 PM   #8
oldspowered67C10
Gotta be careful when getting cams for Olds engines, some of the early 400s and 425s had a 45 degree lifter angle while most later ones(455s) had 39 degree. If Im not mistaken, most(all?) 425s had forged cranks though.
oldspowered67C10 is offline   Reply With Quote
Old 04-19-2013, 09:39 PM   #9
turp mcspray
turp mcspray's Avatar
Boats and trucks require the same thing...low end torque!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 04-20-2013, 12:12 AM   #10
Roninwolf
Roninwolf's Avatar
I am a Inboard Boat Mechanic and most boat engines start as factory longblock truck engines or car performance engines then are finished out with wet exhaust, marine waterpumps (which are diff than cars and trucks because they need antifreeze to lubricate) and flame arrested starters, alts, ignitions and marine fuelpumps and carbs or fuel inj. Some intakes have brass water jackets for aluminum because electrolosis will eat up aluminum. But have seen ppl put all kinds of cams and car parts in them so you never know.The new 6.0's have 409 hp with closed water cooling systems so the engine has antifreeze in them with a freashwater cooled heat exchanger and wet exhaust.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=531265
72 Cheyenne Super
90 Z71 S.B. 434 C.I. Stroker
78 Camaro Z28 (gave to wife she is restoring it)
Roninwolf is offline   Reply With Quote
Old 04-20-2013, 11:00 AM   #11
brad_man_72
the boat guy
My only hope is that a nice jetboat isn't going to die to keep a truck on the road. Most old hotboats sell for less than what it would cost to build the drivetrain. So many old boats have been scrapped after stealing their engine.
Old 04-20-2013, 02:03 PM   #12
kaynnon
kaynnon's Avatar
put it in and use it like it is, on weekends strap a set of ski's to the tires and take it out and fish from the bed. win win
72 Cheyenne LWB
kaynnon is offline   Reply With Quote
Old 04-20-2013, 06:43 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yup... and a cam swap would be EZPZ to do before installing it in the truck.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
