Old 04-19-2013, 03:28 PM   #1
AirSpeed
AirSpeed's Avatar
Suggestions for replacing gas line from tank to carb
I just got done replacing the trans cooler lines in my 72 and while I was under there I noticed my gas lines are in rough shape, they've been bent up and the hose is getting old. The line from the pump to the carb is trash, rubbing against the block on its way up. Anyway I want to replace it all and was looking for any tips before I get into it. What do I have to look forward to? I also noticed an extra line against the frame, its right below the bottom rad hose, it has cooling coils around it and it's not connected to anything and ends near the back of the cab, it has the remnants of a broken rubber hose on the end. Any idea what this may be? Thanks for any suggestions!
AirSpeed is offline   Reply With Quote
Old 04-19-2013, 04:14 PM   #2
cdowns
cdowns's Avatar
Re: Suggestions for replacing gas line from tank to carb
that remnant would b the vent line that goes from the tank up to the charcoal cannister that is located under the battery by the core support
Old 04-19-2013, 04:41 PM   #3
SS Tim
SS Tim's Avatar
Section 8 in the Chassis Service Manual has a lot of illustrations to clear things up.
SS Tim is offline   Reply With Quote
