Old 04-19-2013, 09:36 PM   #1
bhc41051
bhc41051's Avatar
Mirror Glass Replacement
Has anyone had any luck replacing mirror glass? I know I should be asking a glass shop but I thought I'd check here.. Plus I can show off my $5.24 + $11.65 shipping offset mount mirror off of Ebay. Was listed as "Vintage truck side mirror"
bhc41051 is offline   Reply With Quote
Old 04-20-2013, 12:06 AM   #2
Lugnutz65
Lugnutz65's Avatar
Re: Mirror Glass Replacement
I own a classic F**D car. I went to a glass shop but they would not install regular mirrored glass in the door mirror. Something about the reflection and the laws about what type of mirror it had to be. So I went to the local O'Reillys and bought a pre-packaged replacement mirror that had enough mirror to do two door mirrors. The glass shop then used that mirror to cut a new piece for my door mirror. Sorry for the long explanation.
Nice offset mirror by the way!
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-20-2013, 01:11 PM   #3
theastronaut
theastronaut's Avatar
We own a glass shop and have cut plenty of side mirrors before. Never have heard that its illegal to use plain mirror? The passenger side mirrors are slightly convex but the drivers side is usually plain flat mirror.
theastronaut is offline   Reply With Quote
Old 04-20-2013, 02:28 PM   #4
HOTFUN
HOTFUN's Avatar
I don't see anywhere in the GM parts book in the 1970 or the 1972 print books for a different part number for that 5" mirror head? They had different versions like the silver 68 up style but nothings about pass or drivers side use. I wonder if they are all slightly convex but either way a new flat mirror glass in a restored head would look awesome. Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 04-20-2013, 03:14 PM   #5
1963c-10
1963c-10's Avatar
great find at a great price. i have several of these off set mirror heads, and they are getting harder to find. i also have a few that could use new glass as the mirror surface was wearing. the only problem i see is that it has a pressed edge that holds the glass in. i dont see how you would remove the glass and get a new piece the same size installed. if you do figure it out though, please let me know. the only option i saw was to break the glass and install a smaller piece that i just dont think would look good. i think they probably replaced the entire mirror head when the glass broke.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-20-2013, 06:23 PM   #6
theastronaut
Ah, I shoulda said that most newer cars have flatter/convex glass. I haven't checked an original round mirror to see what they have. Sorry about the confusion.
I was planning on cutting a mirror slightly smaller for mine, then use black silicone to hide the gap. We have a circle cutter to get the glass as round as possible to minimize the gap and uneven edges.
Old 04-20-2013, 07:58 PM   #7
1963c-10
1963c-10's Avatar
im looking forward to the finished product. if it works for you, ill try it out. i have two really nice ones and two that need replaced due to finish, but glass isnt broken on any of them. seems old age was the nemesis in the ones i have
Old 04-20-2013, 08:03 PM   #8
1963c-10
1963c-10's Avatar
original part # for these off set stud mirror heads is 3838535
Old 04-20-2013, 09:45 PM   #9
HOTFUN
HOTFUN's Avatar
1963-10 Yeah sorry, I should have posted that # when I looked that up.
Astronaut: I too would be interested in seeing the finished product. I have several off set stud mirrors that look like 47 some year olds in the glass appearance and the reflection too looks even worse when I look at it!
'72 GMC K2500 4x4
Old 04-20-2013, 10:39 PM   #10
theastronaut
I still need to find a second mirror head before I restore the one I have- I'm going to paint then with flattened single stage urethane and the sheen won't match if I do them at different times. I'll go ahead and get the first one ready to paint though to speed up the process.
Old 04-20-2013, 10:49 PM   #11
theastronaut
We can get convex mirror to cut passenger side mirrors so they'll have a wider viewing range like newer cars have. They are pre-cut replacement mirrors for newer cars but we can cut them down to fit the truck mirrors.
Old 04-22-2013, 12:58 AM   #12
bhc41051
bhc41051's Avatar
Thanks to all for the information.. I get so side-tracked on little detail items when I should be focused on getting my cab set back on the frame...
