![]() Join Date: Jul 2006
Overload leaf?
Is this the factory overload leaf (bottom)? Any reason not to remove it when I do the flip kit?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
Re: Overload leaf?
No it is not.
It's the main spring rest or something. If you remove it your springs will likely break. |
Re: Overload leaf?
I'm 100% positive it won't cause anything to break...removing it will make the only cause the bearing point of the next spring to be on the saddle, or in the case of a flip kit the plate. I think I can get about an extra 1/2" of drop without it.
Just to be sure we're looking at the same thing I'm talking about the bottom leaf (circled).
Re: Overload leaf?
nothing will break.
Im with you, once its flipped what purpose does it serve?
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Re: Overload leaf?
Come to think of it, there will be absolutely no gain by removing it once the axle is located on top...DOH! Dumb question here...nothing to see!
Re: Overload leaf?
Less weight?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
I know the pieces fit
Re: Overload leaf?
It'll look a little cleaner. I'd consider it for aesthetics if nothing else if you're not going to tow/haul anything heavy.
