Old 04-20-2013, 09:53 PM   #1
UATahoe
Installing new knock sensor, got a question....
Just curious. Installed my new knock sensor and wanted to know if its typical to still have this many threads exposed? I tightened it way down and didn't want to strip it out. Thoughts?
UATahoe is offline   Reply With Quote
Old 04-21-2013, 07:42 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Installing new knock sensor, got a question....
You're good, it won't leak. The cooling system isn't under much pressure so snug is sufficient.
Old 04-21-2013, 09:07 AM   #3
Desert1957
Desert1957's Avatar
One thing I will mention about "Knock Sensors" When I swap my 305 for my 350, sensor called for a different part number.
After some research the only reason I could find was one sensor was less sensitive then the other.
Desert
PS: my sensor looks like yours when installed
Desert1957 is offline   Reply With Quote
Old 04-21-2013, 10:05 AM   #4
77c10
77c10's Avatar
Did you get yours trans built from the guy in Franklin?
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 04-21-2013, 11:10 AM   #5
UATahoe
I did not actually. I ended up going with a local shop about 10 minutes away. They were highly recommended and gave a better warranty. Have you got yours up and running?
Old 04-21-2013, 11:11 AM   #6
UATahoe
Thanks guys for the info! Getting close to throwing this back in the truck!
Old 04-21-2013, 11:26 AM   #7
77c10
77c10's Avatar
Yep, I like it so far. Having trouble getting the speedo to work.
Old 04-21-2013, 11:33 AM   #8
UATahoe
Yeah I am hoping I don't have trouble there. Replaced the drive and driven gears on mine to account for the new 3.73 gears going in.
Old 04-21-2013, 01:38 PM   #9
77c10
77c10's Avatar
I figured out with some help from this forum that I have the wrong gear housing for my drive gear. I ordered one off Ebay this morning.
