Old 04-20-2013, 11:16 PM   #1
cswolley
67 stepside backspacing advise
I have a 67 c-10 stepside lowered 4 up front and 6 in the rear. I would like to go with 18" american racing torq thrust II. I' am looking for advise or pictures of backspacing and tire size.
cswolley is offline   Reply With Quote
Old 04-20-2013, 11:36 PM   #2
cubber
Re: 67 stepside backspacing advise
If I'm not mistken, you will want a 5" bs. Here's my 69 with a 17x8 with 4.5 bs, but I have the wider 71-72 rearend.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 04-20-2013, 11:50 PM   #3
buckskins4ever
buckskins4ever's Avatar
5 inch bs with 8 or 9 rim will keep u tucked under.
buckskins4ever is offline   Reply With Quote
Old 04-22-2013, 11:56 AM   #4
68Stepbed
68Stepbed's Avatar
Well first we need to know which rearend you have. Then we need to know what width rim you want to run.
For example, I have 17x9.5" wheels on a wider 72 rearend. The wheels have 5.5" backspacing and ub the inner bedside, so I have to use 7/16" spacers. 5" backspace would have been perfect. If you have the narrower 67-70 rearend, you will need a 4.25" backspace.
If you only plan to run an 8 or 8.5" wide wheels then anywhere between 4-4.5" backspace is just right.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-24-2013, 10:29 PM   #5
cswolley
Thanks for the replies. I have the narrow rear end and would like to go with 9.5" wheel on the back.
