04-21-2013, 01:07 AM | #1 |
Rectangle holes on rear pillars...do i need them?
I am cleaning up and painting etc...Wondering what these holes are for and if I need them for anything? What are you guys doing with them? Would it be fine to weld them shut?
Also...The seam on the roof toward the back of burbs...any problems that arise from welding that up?
Aaron Anderson *1971 GMC Burban - Daily *1962 Nova |
04-21-2013, 01:17 AM | #2 |
Re: Rectangle holes on rear pillars...do i need them?
The rectangle holes are for the other option on the doors. If you have the clam shell, your hinges are in the top and bottom set of hinge points, and with barns, the hinges are on the right and left pillars.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
04-21-2013, 11:54 AM | #3 |
Ahh...Gotcha. So If I never want barn doors then I can close them up.
04-21-2013, 12:27 PM | #4 |
Yes.
04-24-2013, 12:01 PM | #5 |
Let me know when you get rid if the little plugs! I need a few for mine.
Shawn Posted via Mobile Device
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
