Old 04-21-2013, 01:24 AM   #1
MikeS.
MikeS.'s Avatar
Overheating?
I've noticed on my 66 motorhome that I have coolant dripping from the overflow tube after driving it. This is normal, right?
It would make sense thus the tube. I don't have an overflow container, yet.
After driving a total of about 400 miles it was down about 5 quarts. Is that normal?
I took it on a 140 mile round trip Saturday, I forgot to check the coolant level before I started off. I did remember to check at the half way mark, fortunately. I had gone to a cruise-in. So she sat for a couple hours and cooled off.
I did check the oil before I drove off from home. I need to get back in the habit of checking fluid levels more often.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 04-21-2013, 01:38 AM   #2
MikeS.
MikeS.'s Avatar
Re: Overheating?
Ohh and the temp. gauge doesn't work...
Past Master
Old 04-21-2013, 11:36 AM   #3
corvettejim1968
corvettejim1968's Avatar
Re: Overheating?
my 1st thought was maybe you need a new cap. and possibly replace the thermostat. these two items don't cost much.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 04-21-2013, 11:38 AM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Overheating?
These rads do seem to hold a lot of water.. 5qts low does seem like a lot.. I would look into a overflow bottle of some kind, that way the system can recover the water when it cools down.
...and get that temp gauge working!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-21-2013, 11:43 AM   #5
corvettejim1968
Re: Overheating?
here is my overflow bottle.
Old 04-21-2013, 11:52 AM   #6
Rich 5150 69
Rich 5150 69's Avatar
Re: Overheating?
Can you get a pic of the radiator, do you have a shroud on it most of all, 5 quarts is a lot, no overflow will hold that much, you might have a rad to small or it needs recoring, and a t-stat and cap is due. You can get the correct sender for the temp gauge at truck and car shop...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-21-2013, 01:21 PM   #7
jayoldschool
Moderator
Re: Overheating?
I have the exact same overflow bottle on my 65 Impala as corvettejim's. However I have no overflow bottle on my 71 Pontiac and it never pukes any coolant, and I have used it on 700 mile road trips with no issue. I would suspect your rad cap first. Get that temp gauge fixed, too. Even if you need to swap the sender for the light one and put in a temp light to warn you.
jayoldschool is offline   Reply With Quote
Old 04-21-2013, 03:44 PM   #8
MikeS.
MikeS.'s Avatar
Re: Overheating?
Ok new cap and thermostat bought. New cap is on, new thermostat I'll get installed this week. I'm trying to find a recovery bottle locally.
I'll work on the temp gauge as well.
Thanks guys.
Past Master
Old 04-21-2013, 06:06 PM   #9
MikeS.
MikeS.'s Avatar
Re: Overheating?
Found a recovery system, now have it installed as well. I'll drive it some this week and see what happens.
Past Master
Old 04-21-2013, 08:30 PM   #10
1964Chevy
1964Chevy's Avatar
Re: Overheating?
I have a question that applies here. I installed a 3 row aluminum rad, the original one was seeping and leaking. I have an electric fan installed. The temp runs up to 215, the thermostat (190 degree) opens and the temp drops to 180, rises to 195 and the fan comes on, then settles at 190 for the duration. My question is this. There is a lot of pressure in the system, the upper hose is tight with pressure. The unlisted rad cap is hard to compress the spring so I installed my old 16 psi cap, but the pressure still builds. I bought a 180 thermo today and am going out to install it right now. is it normal for the hoses to be tight with pressure when the engine is hot?
Thanks in advance.
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb
1964Chevy is offline   Reply With Quote
Old 04-21-2013, 08:42 PM   #11
jayoldschool
Moderator
Re: Overheating?
Check your bottom hose to make sure it is not collapsing under pressure.
Old 04-21-2013, 09:11 PM   #12
MARTYZ
MARTYZ's Avatar
Re: Overheating?
1964CHEVY, sounds like your cooling system is doing its job normally, and yes you will have pressure on hoses when warm. Purpose of the cap no pressure water will be boiling, pressure raises the boiling temp of coolant.
MARTYZ is offline   Reply With Quote
Old 04-21-2013, 10:10 PM   #13
1964Chevy
1964Chevy's Avatar
Re: Overheating?
Thanks for the response guys. Bottom hose is tight too.
I just put a 180 thermostat in and ran it around, the temp never got over 190 and settled at 185. I can definately live with that. Yes there was still pressure. I read on this great web site that someone put in a new radiator and new cap and the pressure blew out the heater core. I am, or was worried about that.
Thanks again and I hope everyone has a great night.
