Old 04-21-2013, 01:49 AM   #1
jydbowtie
jydbowtie's Avatar
Newb: 1982 k10
Hey guys I just picked this truck up today I love it so far. Slowly I will do the things that I want to it. The body is straight, and will make a good truck. I was wanting to put a 4 inch lift and 35 inch tires. Do you guys think the tires would be ok with just a 4 inch lift?
jydbowtie is offline   Reply With Quote
Old 04-21-2013, 07:23 AM   #2
pwradder
pwradder's Avatar
Re: Newb: 1982 k10
looks like a good truck to start with! if you plan on using you're stock wheels, you should have no problem. i had 10'' wide wheels on my one ton with a 4'' lift and 35's and they rubbed pretty good.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 04-21-2013, 08:47 AM   #3
rs74
rs74's Avatar
Re: Newb: 1982 k10
Looks like a good truck to start with there. My thoughts are if you put the 4" lift on it then you will want at least 33's or maybe even 35's. I think the tires you have on it now will look to small and out of proportion. My old 84 K10 that I used to have had no lift and 32's were the biggest tire I could put on it without rubbing.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-21-2013, 11:20 AM   #4
dieseldawg142
dieseldawg142's Avatar
Re: Newb: 1982 k10
my k5 had a 4" lift with 35x12.5x15 tires on 8" rally's with no rubbing, even under compression or full lock. mind you, what size is stamped on the sidewall is rarely what you get. if a tire is 34.2 tall, why is it listed as a 35? more accurate sizing would make it easier for people ( does this fit or does that fit?) to chose
that looks like a hickey or smittybuilt pushbar in your box
dieseldawg142 is offline   Reply With Quote
Old 04-21-2013, 07:18 PM   #5
jydbowtie
jydbowtie's Avatar
Re: Newb: 1982 k10
Yea that pushbar my dad had laying around. Think I am going to clean it up and throw it on. Thanks for the responses.
Old 04-21-2013, 07:21 PM   #6
Space Monkey
Re: Newb: 1982 k10
I've got 37" tires on 16.5" rims with a 6" lift and mine don't rub. I think you'd be ok.
I'm a newb too though so what do I know lol.
1982 GMC C1500 4x4 w/ 305 and sm465.
2002 Kawasaki Ninja 250.
2007 Dodge Nitro.
Space Monkey is offline   Reply With Quote
Old 04-21-2013, 07:44 PM   #7
b454rat
Re: Newb: 1982 k10
That is a good looking truck!!!! You should be able to run 35s on an 8" wheel. I run 38.5s on 4" and don't rub....anymore, after I got the sawzall out....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 04-21-2013, 08:24 PM   #8
jydbowtie
jydbowtie's Avatar
Re: Newb: 1982 k10
Thanks guys. Another question, and bear in mind I am new to all this. I really like the quad headlights vs what i have. Can i change it to the quad headlights? I will also try to keep adding pictures as I make changes.
Old 04-21-2013, 09:02 PM   #9
b454rat
Re: Newb: 1982 k10
Which style quad lights? If your talking stacked on top of each other, I think that is just a matter of finding the parts. If your talking the 89-91 style that are side by side, then you will need to change your core support and wiring some...
Old 04-21-2013, 09:57 PM   #10
jydbowtie
jydbowtie's Avatar
Re: Newb: 1982 k10
I was thinking of stacked on top of each other. I just prefer that look
Old 04-22-2013, 01:57 AM   #11
andrewmp6
Re: Newb: 1982 k10
He wants the 81-87 style stacked head lights.
andrewmp6 is offline   Reply With Quote
Old 04-25-2013, 07:32 PM   #12
jydbowtie
jydbowtie's Avatar
Re: Newb: 1982 k10
So can I just buy the stacked headlight assembly and put a phantom grille on it or do I have to buy the whole new grille assembly with the tacked headlights first.?
Old 05-04-2013, 10:49 PM   #13
jydbowtie
jydbowtie's Avatar
Re: Newb: 1982 k10
some progress
Old 05-04-2013, 11:23 PM   #14
andrewmp6
Re: Newb: 1982 k10
I'm kinda shocked you found a rust free truck in Montana.
Old 05-04-2013, 11:47 PM   #15
jydbowtie
jydbowtie's Avatar
Re: Newb: 1982 k10
Yea I actually got pretty lucky.
Old 07-07-2013, 01:05 PM   #16
jydbowtie
jydbowtie's Avatar
Re: Newb: 1982 k10
My progress so far.
Old 07-07-2013, 06:51 PM   #17
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Re: Newb: 1982 k10
VERY NICE!!!!!
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 07-07-2013, 10:19 PM   #18
jydbowtie
jydbowtie's Avatar
Re: Newb: 1982 k10
Thanks still got lots of work yet but tires and rims will really help.
Old 07-08-2013, 12:38 AM   #19
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Newb: 1982 k10
Nice looking good. It is possible to find rust free trucks in MT just gotta look harder haha. Sweet truck keep up the good work on it
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 08-01-2013, 08:26 PM   #20
jydbowtie
jydbowtie's Avatar
Re: Newb: 1982 k10
Old 08-01-2013, 08:29 PM   #21
jydbowtie
jydbowtie's Avatar
Re: Newb: 1982 k10
Some used tires and the new rims!!
Old 08-01-2013, 10:32 PM   #22
jydbowtie
jydbowtie's Avatar
Re: Newb: 1982 k10
Better pic
Old 08-02-2013, 08:48 PM   #23
chevy1ton
chevy1ton's Avatar
Re: Newb: 1982 k10
Quite a transformation, looks like a totally different truck...I like.
chevy1ton is offline   Reply With Quote
Old 08-02-2013, 09:37 PM   #24
jydbowtie
jydbowtie's Avatar
Re: Newb: 1982 k10
Thanks man, it has been a ton of fun so far.
