04-21-2013, 10:39 AM | #1 |
gas pedal mount>
Does anyone make a mount that bolts in to mount he gas drive by wire gas pedal?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-21-2013, 03:34 PM | #2 |
Re: gas pedal mount>
I actually used the original mount out of a 2006 Tahoe that my drive train came out of if you look at the picture I just kept bending the lower mount to match the floor then made two spacers for the other two mounting hole which you can't see. The spacers actually go between the pedal bracket and firewall. Also that upper mount on left theirs one just like it behind the pedal it also bends to the left. The spacers are for the upper mounts hope you under stood that. Really worked slick got it almost right in the original spot
Posted via Mobile Device |
04-21-2013, 07:12 PM | #3 |
meowMEOWmeowMEOW
Take a look at my build, we used a cut steel piece and a custom pedal-arm and fit it up. It gives us a little more let room because it puts thr pedal as "deep" as it can go while still Maxes out at the carpet.
04-24-2013, 01:48 PM | #4 |
Location: Sunny, Florida, some might call it South Alabama
Not trying to hijack this thread...but do you get much travel out of that pedal? On my pedal, closed to wide open is only like an inch of movement
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
04-27-2013, 09:07 AM | #5 |
My DBW pedal is out of an 01 GMC Yukon, I combined the DBW with the base and pedal arm from my 71 and it works great and bolts up to the factory holes. It has full throttle/travel and works great.
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy C-30 1-ton 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2005 Dodge Ram 2500 5.9 Cummins 2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins 2020 Jeep Wrangler Unlimited Rubicon |
04-27-2013, 11:52 AM | #6 |
meowMEOWmeowMEOW
04-27-2013, 12:22 PM | #7 |
That's nice but it might shoot my eye out ha ha.
07-05-2013, 04:46 PM | #8 |
this is what i ended up doing
07-05-2013, 09:55 PM | #9 |
Truck and auto performance nut
my pedal is a later model dbw like post #2. there is no metal base or shaft, they are totally composite so my welder was of no use. I have a block in place for now but like the bracket for it as posted in #2 and can see something similar as a future upgrade.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
07-24-2013, 02:21 PM | #10 |
I used an 05-13 Corvette pedal and made a bracket thats bolts on like the LFD pedal mount.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-27-2013 at 03:54 PM. |
07-25-2013, 09:37 PM | #11 |
That complete assembly (minus the fabricated base plate) is '05 up Vette?
07-25-2013, 11:26 PM | #12 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-26-2013, 08:14 PM | #13 |
Oh I hope I can use that on my genIV! '05 Vette.....IIRC that would be LS2 right?
07-26-2013, 10:13 PM | #14 |
The Waco Kid
07-27-2013, 03:22 PM | #15 | |
I'm not sure. You'll have to ask the whoever is building your harness, but I don't see why it wouldn't work. Posted via Mobile Device
07-30-2013, 09:12 PM | #16 |
I got an 05 pedal which has a massive throw for wide open and its annoying because its sit almost higher than the gas pedal i need to take a look at it because its not right lol
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
08-12-2013, 01:32 PM | #17 |
"You can use a Corvette pedal instead of a truck pedal with the proper pining. Can't substitute it on a Trailblazer setup though." Quote from John at Speartech in regards to the Corvette pedal.
