![]() Join Date: May 2003
? Headbaord metal / wood
Can someone tell me how to tell the difference between headboards for metal floors verses wood floors ? I have one but not sure witch it is for.
Thanks Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 04-21-2013 at 12:32 PM. |
Re: ? Headbaord metal / wood
Heard the differences are the lip or flange on the bottom where the wood or metal floor would overlap. Does anyone have a pic of the differences? I am curious also if it is possible to modify a metal head board for one to suit the wood.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
![]() Join Date: Dec 2012
Speaking of Headboards, I need for for my 59
1971 GMC Sierra 1959 GMC 100 |
Rusty Nuts
The only difference I know of is, the one for the wood floor is 1/2 in taller. Sorry I don't know what that height is right now. When I get to the shop I will measure it and post the height
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
If it is a slight 1/2" difference is it possible to use an angle strip for the sides of a step bed to raise or lower for the header? Still looking for pics if anyone has them.
![]() Join Date: Feb 2012
Look at this thread. http://67-72chevytrucks.com/vboard/s...php?t=533405It shows pictures of my headboard. The bolt holes in the head board did not line up for the wood. All the other holes in the bed braces ect did line up. I did not have to put any angle strip in the front. In the end I just drilled new holes in it.
68 Chevy Short Stepside 250, 3 on tree |
The parts manual shows 19.5" for the metal and 20.5" for the wood floor. These are very likely rounded as a parts reference. The bed wood itself is about .75-.81" thick. The factory inside spec height is 19.22" for either style from the rub strip to the top of the bed. The bed wood itself rests on the front angle and is clamped to it by the strips.
Remember if you are doing a metal to wood conversion the front panel is taller (extending lower), all the sills are shorter for the thicker wood and the rear sill is different with a lip for the wood to lay in just forward of the tailgate. While I am sure it is possible to alter a front panel by extending it down the differnce, remember you will be welding to a single layer panel at or just above the floor line. Here are two pictures of a wood bed being documented and its faults are labeled. Plus a factory general bed spec table.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#8 | |
The 47-59 classifieds would be the place to look for a used front panel not here in the 67-72 message board.
Thanks for the info !!! I'll have to measure it tonight to see witch I have ! Thanks again ! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
