Old 04-21-2013, 11:51 AM   #1
Gigem
Gigem's Avatar
No brakes lights, need ideas
Switch is bench tested good
Bulbs are bench tested good, both filaments
Rear running lights work fine
Rear turn lights work fine
No brake lights. When i had the switch removed for testing, I also tried jumping the wires at the switch plug, no joy.
I suck at wiring. Any ideas?
A ground somewhere?
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Gigem is offline   Reply With Quote
Old 04-21-2013, 01:16 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: No brakes lights, need ideas
Check your fuse?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 04-21-2013, 01:29 PM   #3
hatzie
Moderator
hatzie's Avatar
The ground is shared by all 6 bulbs in the tail... The turnsignals work so the filaments will light.
The 4-way hazards work??? No? Replace the STOP HAZ fuse.
Turn signal stalk set to fully cancelled position??? Brake lamps go through the turnsignal switch.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-21-2013, 01:51 PM   #4
Gigem
Gigem's Avatar
Fuse was it. Thanks guys!
Old 04-21-2013, 03:03 PM   #5
Gigem
Gigem's Avatar
Spoke too soon... Fuse is symptom, not root cause. Replaced fuse, and it blew as soon as I stepped on the brakes. 20A fuse. Hazards did not blow fuse. Ideas?
Old 04-21-2013, 05:32 PM   #6
hatzie
Moderator
hatzie's Avatar
The White wire from brake light to turnsignal switch is probably chafed and grounding either between the brake pedal and the harmonica connector on the bottom of the column. OR. Between the harmonica connector and the turnsignal switch inside the column.
My money is on the short White wire inside the column.
Old 04-21-2013, 05:59 PM   #7
463
463's Avatar
X2 - there is a short > and you have a tilt colomn right?
Trueman
463 is offline   Reply With Quote
Old 04-21-2013, 09:07 PM   #8
Gigem
Gigem's Avatar
Yes, I do have a tilt column...
Old 04-22-2013, 01:58 AM   #9
hatzie
Moderator
hatzie's Avatar
If it's in the column you'll have to pull the turnsignal switch assembly off far enough to reach the wires.
You should be able to carefully release the terminal from the harmonica connector, slip the WHITE wire up and out of the column with a string tied to it and slip a piece of heatshrink over the wire or paint on several layers of liquid electrical tape to cover the damaged PVC insulation Then pull it back in using the string, and latch the terminal back into the harmonica.
It's not as bad as it sounds just time consuming and fussy.
All of the 1980 GM factory service manuals are in my sig.
Old 04-22-2013, 10:49 AM   #10
463
463's Avatar
I have had the white wire right at the harmonica connector crack enough wires for it to fail and the plastic cover hold it on.
hatzie has a good idea also.
Trueman
Old 04-22-2013, 11:52 AM   #11
Jonboy
Slots go on anything!
Mine was a problem at the long connector also. The wire on mine backed out, and wasn't making contact. I would start at that connector.
Old 04-22-2013, 05:04 PM   #12
hatzie
Moderator
hatzie's Avatar
You can find the 1980 tilt column on PG 6-42 & PG 6-43 in the 1979-1984 GM 52A Light Truck Parts-Illustration books. Follow the links to GM parts wiki host site for our square body parts manuals.
If the wiring is too far gone... The GM-AC-Delco turnsignal switch part # for your 1980 Tilt Column is 1997985. You can buy that AC Delco switch, brand new, on Amazon for $20. http://www.amazon.com/ACDelco-1997985-Switch-Assem... http://www.amazon.com/ACDelco-1997985-Switch-Assem...
Make sure the plastic wiring protector is in place and the wires are running along it instead of rubbing on the internals of the column.
Automatic protector is GM # 7828270
Manual protector is GM #7817247
