Old 04-21-2013, 11:52 AM   #1
ArlenC72
ArlenC72's Avatar
72 Chevy 3/4ton 4x4 complete rolling frame
I have a complete rolling 3/4ton 4x4 frame, was a complete running truck a few weeks ago, trans, t-case, brakes and steering were all working fine. Has a 4-speed, 205 tcase, both drive shafts, front dana 44 with 4.10 gears, rear was swapped to a 14bolt full floater with 4.10 gears. Power disk brakes, power steering, includes ps pump and bracket still attached. I have the power disk brake booster, mc, and bracket as well as the manual pedal assembly. Also have a very nice 72 gmc cab with a solid floor, good core support, hood, pass fender, and good doors.
complete rolling frame 800
good cab and parts 450
may part out if noone wants it complete, thanks.
ArlenC72 is offline   Reply With Quote
Old 04-21-2013, 03:20 PM   #2
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: 72 Chevy 3/4ton 4x4 complete rolling frame
Why would you part out a running 4x4 unless the frame was bad? How much for everything to put it back together again?
I will at least take the good cab and parts for 450 assuming theres no rust in the visor area inside and out
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 04-21-2013, 03:37 PM   #3
ArlenC72
ArlenC72's Avatar
Vintage windmills- the blue cab is not a factory high hump cab, it came on a 72 3/4 ton 2wd truck. The cab that came on the 4x4 frame was so full of rust I scrapped it. The cab I have is solid above the visors, kick panels are good as well as the cab supports. Only thing I found that is needs are outer rockers and a very small area on cab corners.
Old 04-21-2013, 06:26 PM   #4
Vintage Windmills
Vintage 4x4s
gotcha, I will take it but what all is included with the cab and parts for 450? Also, do you have matching title and vin plate for the frame that is correct for 1972 K20? Vins should begin with CKE242 or CKS242
Old 04-21-2013, 08:05 PM   #5
jimer1964
jimer1964's Avatar
good deal on some vintage stuff! good thing it not in my driving range! i would be all over it! interested in fender if you will ship!
jimer1964 is offline   Reply With Quote
Old 04-21-2013, 09:43 PM   #6
john@thepier
john@thepier's Avatar
I'm very interested in the rolling chasis. How quick will it need to be picked up? I would need a little bit of time, we are in the middle of hatching walleyes for another week or two. Thanks John
john@thepier is offline   Reply With Quote
Old 04-21-2013, 11:27 PM   #7
71GeneralMotorsCorp
i'm very interested and can pick up.. are you interested in any trades?
"Repetition penetrates even the dullest of minds"
71GeneralMotorsCorp is offline   Reply With Quote
Old 04-22-2013, 09:09 AM   #8
ArlenC72
ArlenC72's Avatar
Frame sold local, keeping the cab for now.
Old 04-22-2013, 11:08 PM   #9
Vintage Windmills
Vintage 4x4s
frustrating... not professional.
