Rear rim measurement question
I measured up the rear wheels this weekend to find out how big of a rim I can run and here are my numbers. Mind you I run a Ford 8.8 rear end (59 1/2" with an offset to the passenger side tubes).
Driver side: From wheel hub face to inside fender (by bed): 4.75" From wheel hub face to outside fender: 7.125" Passenger side (offset): From wheel hub face to inside fender (by bed): 4.75" From wheel hub face to outside fender: 6.75". So the shortest side (pass), I have a total of 11.5". I figured with an 8" rim and 2" of swell (from the tire) I would be in the clear. The rims I want to run are 15x8 with BS 3.75". So in my mind, I thought I will be fine with those rims and still have clearance on the sides. This is my first time measuring for rims so I wanted to make sure I did it right and also see what you guys thought. Thanks. Posted via Mobile Device
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
Re: Rear rim measurement question
Anyone?
I think with 3.75 backspacing plus 1" you will have 4.75 and contact with the bed.
this problem is why I am going to build some mini tubs from a trailer fender It gains 2" per side on a 1/2 ton AD and maybe more on a 3/4 ton |
![]() ![]() Join Date: Nov 2008
You don't need us to figure it out, you can do it yourself:
http://www.gtsparkplugs.com/WheelOffsetCalc.html http://www.1010tires.com/Tools/Wheel-Offset-Calculator http://www.rimsntires.com/specs.jsp |
