04-21-2013, 05:51 PM | #1 |
C35 Crew Dually
Replacing the flex plate
Replacing my flex plate tomorrow. Whats the easiest way to do it? Slide trans back wards or motor forward? Im thinking the trans :/ but not sure
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
04-21-2013, 05:52 PM | #2 |
Watch out for your cornhole !
Re: Replacing the flex plate
Transmission back. No doubt.
Posted via Mobile Device |
04-21-2013, 06:03 PM | #3 |
x2 for sure!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
04-21-2013, 06:06 PM | #4 |
i agree , drop drive shaft and slide trans back.... Just replaced one in my truck this week...
04-21-2013, 09:54 PM | #5 |
C35 Crew Dually
Thanks guys! Ill keep ya posted on how it goes!
04-22-2013, 07:54 AM | #6 |
You guys ever have issues changing these since they aren't balance matched with rotating assembly? Like too much run out?
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
04-22-2013, 08:03 AM | #7 |
No. Changed many, many flex plates in the dealership, independent shops, and my own shop. Never an issue. I use Pioneer brand flex plates from the parts store. Bolt them on and put it back together.
04-22-2013, 08:07 AM | #8 |
If you have a internally balanced engine you should have no issues by just getting the proper flex plate or your truck , motor year etc...
for externally balanced.. "if there is no counterbalance weight on the flywheel just take it and have it balanced by itself. If there is a counterbalance weight welded to the flywheel take the new one and bolt the old one to it only with the balance weight on the opposite side. then balance the two together but only adding or subtracting weight from the new plate. when finished the new plate will match the old one"
69 c10 step side shorty ( resto ariz truck ) 85 shortbed lifted , 454 68 camaro i frame off restored 83 lifted stepside lifted 2011 tahoe |
04-22-2013, 01:01 PM | #9 |
Okay I was just curious, when I had my 350 rotating assembly balanced they asked me to bring new flex too and I could see where they removed some material from the weight thats welded on it....mine was pioneer too.
04-22-2013, 01:52 PM | #10 |
It sounds like your engine build is well above the level of a stock engine. On a driver with a generic engine, a little bit of unbalance isn't noticeable. With your balanced rotating assembly, you've got more investment than most folks, who just want their starter to catch smoothly and not make horrible noises.
04-22-2013, 04:49 PM | #11 |
id suggest taking the old flexplate and the new one to the machinest and have him match them up.
04-22-2013, 07:03 PM | #12 | |
04-22-2013, 07:29 PM | #13 |
You're not the average Joe since you ponied up to have your stuff balanced. Most people out there on the road wouldn't notice any vibration as long as they can still see to text on their smartphone while driving in traffic.
04-23-2013, 09:35 AM | #14 |
Lol
I had USA racing engines (wop shop) do the machine/ balance work but my buddy and I assembled everything Back to flex plates. Is it better to buy an SFI since its thicker and probably have less run out?
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB Last edited by 88Jimmy4x4; 04-23-2013 at 09:41 AM. |
04-23-2013, 10:09 AM | #15 |
78K & 79C Jimmys
took my motor out ,not the easiest way....tranny back usally is
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-23-2013, 10:23 AM | #16 |
Runout isn't a real big issue on a flex plate... they are supposed to flex. They'll take whatever shape the torque converter mounting points have and bend to allow movement between the engine and transmission under varying conditions. You don't mention the torque converter, if you're concerned about flex plate balance you should be matching that to the engine as well. Really though, a properly balanced engine is the most important and it sounds like you have that. Matching the torque converter and flex plate are crossing over into diminishing returns. Unless you need the SFI rating for passing inspection, or you do things that would put it under race like stress, it's not necessary.
04-23-2013, 06:30 PM | #17 |
C35 Crew Dually
Project flex plate was completed today buddy came to help and was done in a few hours. And went incrediably smooth. Old teeth were rounded and tapered inward. Ie not flat across like the new plate.
04-23-2013, 08:28 PM | #18 | |
04-23-2013, 10:14 PM | #19 |
C35 Crew Dually
I take back what i said earlier.... She's back to square one. Trucks back to grinding when I start it. I have more than a few bad words to say about this..... New starter new flex plate im at a loss
04-23-2013, 10:33 PM | #20 |
Have you tried shimming it out a bit?
04-23-2013, 11:07 PM | #21 |
C35 Crew Dually
Yeah shimed it but it did nothing. Like all the normal things you do to correct this issue doesn't fix the issue
04-23-2013, 11:40 PM | #22 |
I had an issue like that with an Isuzu rodeo turned out it was the starter it had a bent shaft. Napa replaced the starter but no joy with the fly wheel
"Not all those who wander are lost." A.R.R. Tolkien... Some of us are exploring to see what is out there in this world! |
04-24-2013, 08:53 AM | #23 | |
C35 Crew Dually
04-24-2013, 09:09 AM | #24 |
Check the mesh between the starter drive and the flywheel. You should just be able to get a paper clip between the teeth of the starter drive and the valley of the teeth on the flywheel. I hope that makes sense?
I have just shimmed the outside bolt to get the mesh right.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
04-24-2013, 09:17 AM | #25 | |
C35 Crew Dually
