Old 04-21-2013, 06:12 PM   #1
bullington
All around good guy
bullington's Avatar
Heater Core Question
Swapping out an older heater core with a new efficient one. For those who swapped them out before what did you use to secure the heater core to the heater unit? The newer design does not work with the older mounts.
bullington is offline   Reply With Quote
Old 04-21-2013, 07:41 PM   #2
vectorit
What?
vectorit's Avatar
Re: Heater Core Question
I just took some metal banding and bent it to fit, then drilled the mounting holes in the band. (I used the banding that is used for heavy freight packing).
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-21-2013, 08:20 PM   #3
bullington
All around good guy
bullington's Avatar
Thanks Chris, I figured I was going to have to fab a solution.
