Rear inner splash shields
So I just converted my steel fleetside bed to a wood floor. The wood floor with with out a hitch, no swearing from all three people. Now the splash shields are a different story. Is there a difference between ones for a steel floor and a wood ? I dont think so, but I got one side to fit but not the other.
Re: Rear inner splash shields
So the problem is with the right inner wheelhouse? How is it not fitting?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Correct, I can get the one bolt in under the wheel housing but then not of the other ones line up and I'm inside the bottom lip where i should be over it on the bottom hole.
I'm just going that they never fit great from the factory. I have some gaps I'm not happy with. Does any one have any pictures ?
