04-22-2013, 01:16 AM | #1 |
Rear 4" drop, did you c-notch? pics please
I measured the top of my rear axle to the bottom of my frame. Travel is 7". Dropping 4" would leave me 3" of travel (not including existing bump stops). Is this enough? With 4" drop, did you notch?
1972 C/10 short step, 327/TH350, Blue Print H8002k Aluminum heads, 268 Lunati Voodoo cam, Lunati lifters, valve springs, roller rockers and Summit Racing dbl roller timing chain, Holley 670 Street Avenger dual line carb, Edelbrock RPM Air Gap intake, Summit ceramic coated long tube headers, Flowmasters, 3:73 gear, 15x10 Wheel Vintique Rallys w/ 295/50 front and rear, 2/4 drop, Custom Sound Head unit, Alpine amp, Fosgate Punch P3, Kenwood 6x9 in the doors, Grant GT w/tilt, B&M MegaShifter...etc |
04-22-2013, 01:41 AM | #2 |
Re: Rear 4" drop, did you c-notch? pics please
Well I haven't done it yet but I have ordered my springs and its gonna be next weekends project I asked other members and checked other posts and they have done 6" with out notching and say its ok if your not towing or putting weight on the rear. You shouldn't have a problem with 4"
Posted via Mobile Device |
04-22-2013, 06:42 AM | #3 |
67-72 parts collector,…
No notch needed.
Don't be surprised if your 4" drop spring result in about 3" lower than you are now. Your original springs should have at least 1" of sag in them. Take some before and after measurement to confirm your actual drop. Posted via Mobile Device
04-22-2013, 07:00 AM | #4 |
I am a Referee of life.
I didn't notch.I do need to do the shock relo I think.It seems like a speed bump occassionally bumps th bumpstops.I think shock relo will stop that but I may need to trim the BS a bit.It's not bad,just enough to tell.
Sorry I don't have a pic on this puter.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-22-2013, 07:33 AM | #5 |
You can go as much as 6" w/o a notch. At 6" you are close and have to be careful not to hit bump[ stops. I know of a truck with 7" drop/no notch and that is leaf sprung.
03-12-2017, 08:35 AM | #6 | |
4" spring and 2" blocks?? or 5" spring and 1" block? not that it matter much, just wondering |
03-12-2017, 09:08 AM | #7 |
I have a 2" block and a 4" spring and no c-notch, although I haven't drove mine yet I do not forsee any issues with it. I do plan to go to a 5" spring to get my wheel tucked a little more though and think I will still be fine
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
04-22-2013, 09:32 AM | #8 |
I just installed ECE 4-in. dropped springs in the rear of my '69 and have no need to notch.
I did need to reposition the shocks though. Cheers! Mickm |
04-22-2013, 11:56 AM | #9 |
No notch required for 4 inches, not even for a six inch.. Here is a pict from when my truck had a 4/6 drop kit from Early classics and it may have bottomed out once in three years. If you are going to carry substantial weight then maybe if not you will be fine.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
04-24-2013, 09:44 AM | #10 |
Ok, thanks. I called a few places including Classic Parts last week just to find the best deal on spindles for the front and coils for the rear. I was asking about drop kits and pricing everything I would need, and a sales rep said that a c-notch was "required" to drop 4" or more. I'm not sure that I've ever heard of anyone c notching unless they're really slamming their truck, so this sort of caught me off guard.
And then I received a Brother's catalog the next day and they also recommend notching for 4" or more for their kits. I already have a 1" block kit in the rear, so I'm thinking about just adding 3" coils out back, along with shock relocating brackets and adjustable track bar, of course and 2.5" spindles in front. Just wanted to double check with you guys first to be sure. The fact is, I refuse to cut open the stereo area in my dash for a CD unit, so I'm going with the "factory" looking stereo with a USB port to operate my MP3 player, so I'm dang sure not gonna cut up my freakin' frame, ya know? But anyway, Thanks again, Sid
04-24-2013, 11:15 AM | #11 |
///Relaxed Atmosphere
they say that cause they want to sell you the c-notch kit. you dont need to c-notch i have 6 inch coils and a 1/2 inch block in the rear NO c-notch and NO problems. id rather take the advise from the board members than the advise of a sales person
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
04-24-2013, 11:19 AM | #12 |
unless you plan to put some serious weight i wouldnt worry about it or plan to go lower in the future then i would c-notch.
04-24-2013, 03:31 PM | #13 |
^^ Sweet stepper !
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
04-26-2013, 08:37 AM | #14 |
For those of you who have 4" coils and wanted more drop, how did you go about it? I have a 4" coil in the rear, but the truck needs another 1.5" or so to really make me happy. Are you just using lowering blocks, or did you also add the modified trac bar, shocks, and shock relocating kit?
Thanks |
04-26-2013, 09:56 AM | #15 |
Yes, at 5.5" rear you'd need to think about shock relocation and an adjustable track bar. Pinion angle becomes an issue if you're particular about it but some people are fine without adjusting it.
04-27-2013, 01:59 PM | #16 |
LET'S GO...MOUNTAINEERS
^^he is absolutely right about pinion angle. I relocated the shocks, put on an adjustable traction bar, and had to shorten the drive shaft.
And thanks sid138. This thing is about 12 years of changing my mind. Posted via Mobile Device
72 SWB/Step |
04-27-2013, 10:05 PM | #17 | |
Ok, I haven't thought about pinion angle or driveshaft length when lowering. Makes sense though, but at what point (inches of drop) do you need to shorten?
04-28-2013, 07:32 AM | #18 | |
72 SWB/Step |
04-28-2013, 09:33 AM | #19 | |
1970 C10 Short Stepper with 71/72 front clip. |
04-28-2013, 12:15 AM | #20 |
Here is mine with a 4/6 ECE drop kit. No notch needed
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130 Club longbed ...cause girls like'em long!!!!! |
04-28-2013, 04:25 AM | #21 |
I always hate these numerical drop threads, it all really depends what you start out as. My Jimmy is getting a mild 12" drop and won't be even close to laying frame... but then again you can practically sit under it now .
04-28-2013, 05:11 PM | #22 |
lol,...with 12" of drop in your future, I totally understand now why you hate drop threads..lol. Good luck, brother, and don't forget before and after pics or it never happened! Can't wait to see it
04-28-2013, 09:41 AM | #23 |
4/6 drop here also no notch. But it will be diggin pavement soon enough, so I'm adding a deep notch
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 Last edited by BigDaddyV; 04-28-2013 at 09:48 AM. Reason: added a pic |
04-28-2013, 03:46 PM | #24 |
Do anyone have pictures of the 4/6 drop with a 1.5 lowering blocks?
04-28-2013, 04:04 PM | #25 | |
Posted via Mobile Device Posted via Mobile Device
