1969 Custom 30 wrecker
Ok, I'm at a loss for ideas on what these things are called so using search it out and I need 2 new ones.
On a 3/4 ton with Eaton rear, the rear outer hubs are held on by 2 large nuts. In between them is a funky looking locking washer with tabs that you bend to lock the outer nut in place. WHAT ARE THEY CALLED??? And where can I buy 2 new ones? Mine have most of the tabs broken from all the years of being put on/off.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Junior Member
Re: C20 Rear wheel nut lock washer?
I forget what they call them, but I found them on NAPA's web site. My local NAPA store said they were a dealer only idem, but their site had them. Hope this helps.
67 C-20 LWB 56 Nomad--- nope, sold it ![]() 75 Stingray 13 Silverado crew cab 08 Trailblazer (wife's) ![]() Pittsburgh, PA |
Thanks, I'll see if they have them.
It is a pretty standard part. Same application in my 72 book going back to 46 and forward to at least 85 in newer listings.
Showing a cross DORMAN Part # 618049 for a $1.88 ea. at Rockauto.com http://www.ebay.com/sch/i.html?_trks...63659&_sacat=0
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Thanks once again Tim! I guess it's called a spindle nut retainer.
Having that Dorman number really helped me search.
I found the price is all over the place on these little things. Autozone wanted $13+ dollars for one! Even Summit was $5.95 each. I went with Rock auto. Getting 2 with the shipping for $5.84 Can't beat that! ![]()
