Old 04-22-2013, 09:11 AM   #1
modernbeat
modernbeat's Avatar
Backdating GMC Grille from '76 to '73 - what parts are needed?
I've got a '76 GMC with a tube grille in it now. I want to go back to an OEM style grille, and would prefer the earlier '73 grille.
Other than the grille and it's fasteners, what else is needed to backdate one? I read somewhere (can't find it now) that some other side pieces?? were required?
modernbeat is offline   Reply With Quote
Old 04-22-2013, 10:33 AM   #2
75chev4x4
75chev4x4's Avatar
Re: Backdating GMC Grille from '76 to '73 - what parts are needed?
You will need the two mounting brackets on the left and right side and also the hood relese to work with the 73-74 grill. Go to ur local yard and find a 73 74 to snag this stuff from.
75chev4x4 is offline   Reply With Quote
Old 04-22-2013, 10:33 AM   #3
Jonboy
Slots go on anything!
You need the center support and 2 outer supports. I have a 73-4 GMC grille here locally, if you need one. No brackets, though.
Old 04-22-2013, 10:38 AM   #4
75chev4x4
75chev4x4's Avatar
Bracket support whatever you wanna call it
Old 04-22-2013, 10:39 AM   #5
75chev4x4
75chev4x4's Avatar
Gottcha I misread sorry
Old 04-22-2013, 01:17 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
I did this exact swap to my 76 gmc. You will need the two outer brackets as stated above, but you will also need different inner vertical brackets as the spacing is different on the 73 grille to the 76 grille by an inch or so (if you want a screw in every hole of grille)
BTW.....There are dimples in the core support near each headlight to designate where to drill/locate the outer brackets.
Heres a pic of the outer brackets
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 04-22-2013, 02:07 PM   #7
bigblock73
yeller
bigblock73's Avatar
All you need is the center support/latch, and outer brackets. The vertical intermediate supports are hard to find, as most were spot welded to the 73/74 core support...but like stated above, you don't really need them. Both trucks i converted did not have them, and it caused no problems.
bigblock73 is offline   Reply With Quote
Old 04-22-2013, 03:45 PM   #8
88Jimmy4x4
88Jimmy4x4's Avatar
Ya I found a set and attached mine, it bugged me not to have them lol
1991 GMC Jimmy 4x4
Old 04-22-2013, 07:22 PM   #9
modernbeat
modernbeat's Avatar
Thanks. Looks like the GMC and Chevy parts are the same for those years? If yes, I spotted a '73 C10 in a local yard and I'll pull the entire core support to get all the pieces.
Old 04-22-2013, 07:24 PM   #10
modernbeat
modernbeat's Avatar
Dang, I bought one and had it shipped. Should have put out a WTB. I live in Casa Linda (White Rock Lake) and work in Plano. I might still like to see if yours is an upgrade to the one I got.
Old 04-22-2013, 09:55 PM   #11
Jonboy
No problem. I have it stashed at work, but it is no big deal to bring it home. If you don't end up needing it, I will stash it in the attic.
Old 04-23-2013, 02:32 AM   #12
bluex
bluex's Avatar
bluex is offline   Reply With Quote
Old 04-23-2013, 08:58 AM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You shouldn't have to change your hood latch. Just the center brace an outer brackets.
Hit the swap meet this weekend and there will be a bunch of them out there I'm sure.
Pate Swap Meet. It's big beyond belief. At the Motor Speedway. I'll be the big hillbilly in the giant sombrero.
Old 04-23-2013, 09:18 AM   #14
modernbeat
modernbeat's Avatar
Yep, I'll be at Pate. I try to always make it. Thanks for the pic of the parts I need. Helps a lot.
Old 04-23-2013, 10:57 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Guys this didn't start as a WTB/For Sale post. If it continues to be one it will be locked.
Everyone is giving you all the information you need with one exception. Do you have an inside hood release? I can't remember if they offered it before 77, so I need to verify. If you do have an internal release, there will be several things that need to be changed to accomplish the external release.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-23-2013, 11:02 AM   #16
Jonboy
'78 is the earliest I have seen the inside hood release.
Old 04-23-2013, 11:08 AM   #17
Tx Firefighter
I wasn't trying to sell mine. I sold two of those sets on the parts board and installed the third set on my 78 project truck.
Posted via my rotary phone as I'm building trucks in my shop
Old 04-23-2013, 04:05 PM   #18
bluex
bluex's Avatar
Funny, here's an entire thread no one has said a word about....
http://67-72chevytrucks.com/vboard/s...d.php?t=575419
Made me think things had changed around here a bit.
Old 04-23-2013, 05:45 PM   #19
88Jimmy4x4
88Jimmy4x4's Avatar
Yezzi name blue so that means he can do WTB and has paid money to do so, whereas the starter of this thread is pink and not paid therefore not allowed.
1991 GMC Jimmy 4x4
Old 04-27-2013, 02:02 PM   #20
modernbeat
modernbeat's Avatar
That's not what happened. I'm looking for info, not parts. But someone offered to sell them and got edited.
