402 BIG BLOCK
4x4 trans crossmember, what years work?
For the 4x4 trans crossmember what years are interchangeable? Will the 73-87 bolt up and work for the 67-72? This is for a np205 case, which i don't think matters.
Thanks Guys.
1967 C10 swb 1970 GMC Jimmy 4x4 2005 Chevy tahoe Z71 2001 Chevy impala |
![]() Join Date: Jan 2003
Re: 4x4 trans crossmember, what years work?
Im doing a complete swap from an 89 suburban (motor, trans, transfer case) and I was able to use the suburban crossmember. 2 bolt holes line up with my 71 Jimmy frame, and I had to drill 2 more. Im not positive on what transfer case it is however.
402 BIG BLOCK
ok. The transcase would be different, I'll do some more checking. Thanks
