Old 04-22-2013, 04:36 PM   #1
Irishbleueyes
Edelbrock Carb Adapter
Ok, I got a 500cfm Edelbrock carb today for my 283 4GC replacment. Do I need an adapter Edelbrock 2696 or will that carb bolt right on?? I don't want to find out the day I take off the old one. Anyone that knows please... Thank you
Irishbleueyes is offline   Reply With Quote
Old 04-22-2013, 05:56 PM   #2
ChuckW
ChuckW's Avatar
Re: Edelbrock Carb Adapter
If I remember correctly the Edelbrock is the same as the old Carter AFB's. They bolted right up to the chevy manifold. Should be a bolt and play! Enjoy!
ChuckW is offline   Reply With Quote
Old 04-22-2013, 06:31 PM   #3
luvbowties
luvbowties's Avatar
Smile Re: Edelbrock Carb Adapter
Chuck's right about Edel being same bolt pattern as AFB. But, the AFB did not have same bolt pattern as the Rochester 4gc. [The 4GC & intake also came on the 250hp/327, while the 300hp/327 came with bigger intake and AFB.] Also, IIRC, you hafta use an adapter to put the Edel on the 4gc intake: the butterflies will interfere with the smaller bore in the 4GC intake; I know for sure we had to use adapters to put AFB's on the 4GC intake.
Lotsa extra info from us, I realize, PLUS no 100% answer to your ?'s. Best we can do.
Unless someone else chimes in with a "for sure", call Edlelbrock & ask 'em. Else, buy an adapter to be sure--not much investment, plus you can always sell it on Craigslist.
Sam
luvbowties is offline   Reply With Quote
Old 04-22-2013, 07:16 PM   #4
Irishbleueyes
Sam
Wow, ok I called Edelebrock like you said and it will not bolt up. The holes are smaller and closer together. They don't make an adapter but they said Trans-Dapt does. Thank God I called... Thanks for the info
Old 04-22-2013, 07:18 PM   #5
Irishbleueyes
Hey, Edelbrock said Trans-Dapt 2064 adapter is needed. The holes are on the manifold are smaller and closer together..
Old 04-22-2013, 07:40 PM   #6
jayoldschool
Moderator
It would be worth it to swap on a better intake. You can grind the name off, and paint it orange
jayoldschool is offline   Reply With Quote
Old 04-22-2013, 08:19 PM   #7
ChuckW
ChuckW's Avatar
Sorry about that.. I totally missed the "Rochester" part... Brain fade.... Again. Guess I have suceeded in putting the QJet out of my mind!
Enjoy!!!!
Old 04-22-2013, 09:50 PM   #8
losthope
losthope's Avatar
it is a good idea to run a carb adapter/spacer since edelbrock carbs are aluminum and the adapter helps with heat placement to keep from warping the base of the carb...(especially on a cast iron intake)...just my 2 cents
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 04-23-2013, 03:43 AM   #9
luvbowties
luvbowties's Avatar
Not sure, but it looks like Speedway Motors--speed shop--item#1351935 may work. The holes are also slightly tapered, again iirc.
>> http://www.speedwaymotors.com/SMISea...Phrase=1351935 <<
Sam
Old 04-23-2013, 04:16 PM   #10
MikeS.
MikeS.'s Avatar
How about a new Edelbrock manifold?
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
