Old 04-22-2013, 08:05 PM   #1
jorgensensc
jorgensensc's Avatar
Starters the same?
I ended up with a starter off a newer silverado with 5.3 for my 6.2 swap. It has the plug instead of the terminal bolt for the ignition wire. Will it work fine for the 6.2? I know it bolts up fine, but I just don't know if the throw of the gear is correct. Just trying to make sure before I try and crank it up. I don't want to break any teeth on anything. I tried to cross reference part numbers and use some common sense, but the part numbers don't cross over for fit, I think because of the plug instead of the ring terminal. But it seams to me it SHOULD work correctly. Any thoughts?
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-23-2013, 12:57 PM   #2
Nitschke
Nitschke's Avatar
Re: Starters the same?
I would like to know this as well.
~72 Chevy Truck~
Motor: LY6 6.0 Liter
Trans: 6L80E
Still under construction
Nitschke is offline   Reply With Quote
Old 04-23-2013, 01:08 PM   #3
Hart_Rod
Hart_Rod's Avatar
My 6.2 (2013 Camaro SS) has the starter with the plug. I think the small high torque starters will work on all setups. I would try to cross check the flywheels and see if they are the same.
Hart_Rod is offline   Reply With Quote
Old 04-23-2013, 11:07 PM   #4
jorgensensc
Thanks for that info Rob. I tried using your info and any info I could figure out. Unfortunately I can't get info that seems reliable or correct. It's like the vehicles are too new and the catalogs aren't updated past 2010, some 2011. They all appear robe 168 tooth fly wheels. However there also appear to be shims used on some vehicles too. I guess I will just have to crank it and see what happens.
Shawn
Old 04-24-2013, 11:46 AM   #5
Hart_Rod
Hart_Rod's Avatar
Shawn
Shawn, I found these threads on LS1Tech:
http://ls1tech.com/forums/conversion...t-starter.html
http://ls1tech.com/forums/conversion...ter-swaps.html
Old 04-28-2013, 11:30 AM   #6
BigShoe24
True Addiction
BigShoe24's Avatar
Hart Rod, thanks for posting the links. I placed an order so hopefully it'll work. Boomer Sooner
RCC
BigShoe24 is offline   Reply With Quote
Old 04-28-2013, 01:45 PM   #7
jorgensensc
Yes rob! Thank you.
