exhaust options.
i have dual turndowns on my blazer right now, it sounds great! but the issue is inside the cab, i have a major drowning issue, all you can here is this loud humming in your ears! i know the best solution would be full tailpipes... but im on a tight budget haha, what do you think about cutting out the side before the rear wheels? good or no good?
Tyler ------------------------------------------------------ 1980 2wd blazer 1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276 1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784 |
I know the pieces fit
Re: exhaust options.
That will help immensely. I think that's the way motornut routed the exhaust on one of his. You've got to get the exhaust exit out from under the vehicle to reduce the noise.
78K & 79C Jimmys
my 79 is out the side,its great
keeps the stink out in the draft, radio no problem my 78 i just put turn downs (a quick fix for now) and pointed them out maybe at @45 between the tires and it stinks with back open of course(are your straight down),sound will bounce off the road? the 78 kinda rumbles/drones now at 1000 rpm (like walking speed) which i like,fades out after both 2.25 see both>>>>>
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#4 | |
i heard somewhere that cutting out the side doesnt sound good without a H pipe because you only hear 4 cylinders at a time, where as with turndowns or tail pipes they are together so you hear all 8. anyone know if theres any truth behind that?
78K & 79C Jimmys
well the 78 dosn't have an H pipe,and i could hear "both sides" when it had tails
so i'd say yes you would hear a slight left/right difference as for hearing 4 cylinders,not really in 1000s of rpm, its continuious and yes it sounds the almost the same left /right with the H but i'd say the X pipe would be even closer too "even" sound, cause no corners to go around lol been thinking of 3" chrome tips for the 79 sides tho..... not sure if I wana say "looky here" lol
i think 3" tips would look good, if you think its to much for your truck you could always go with 2.5" tips, as long as they dont stick out to far and arent to big i think tips look good!
#7 | |
78K & 79C Jimmys
seeing it at eye level most will see the smaller inside pipe anyway Posted via Mobile Device
Your choice of muffler will also have an effect on the interior drone. Flowmaster Super 44's for instance will always have interior noise no matter where the exhaust is exiting. Super 50's will be quiet inside and medium outside.
i have the super 40s, theyre pretty loud so i can see the causing a a lot ofmy issue, but i like the sound.
