Differences between 3100 beds 47-53 and 54-early 55
I am working on a 54 3100 and would like to use the art morrison frame assemby. They say their frame is for 47-53 only because the beds are different. They claim the cab of the 54 will still mount just fine but that i would have to change beds to a 53 or older style but they cant tell me why other than their "engineers" said it wont work. I am hoping for some insight into this from you guys and i also hope its something that i can overcome on my end with modifications to make my 54 bed work. Thanks
ETA, maybe what i should be asking is what would it take to make a 54 bed mount on a 53 and prior frame and make it line up correctly? Last edited by DENALI; 04-23-2013 at 01:02 PM. |
Re: Differences between 3100 beds 47-53 and 54-early 55
As far as I know, there shouldn't be any difference.
Before I got lucky enough to get my bed, I researched what beds I could fit instead. Everything from chevy beds from 41-80, to dodge beds.....even ford beds. Ha ha If there IS a difference, it's going to be in the spacing between the cross pieces on the bed. Which means all you'll need to do is drill a few new holes. |
![]() ![]() Join Date: Nov 2008
I can't speak for 47.5 and newer but I can tell you for sure that a '41 bed (which is the same for a '42 & '46 to '47.1) is tiny by comparison to a newer bed. It is entirely different and I know because I owned a '46 truck that; as it turned out, had a '41 cab (slight difference in how the rear window installed or I' have never known).
The 1954-55 (1st Ser.) rear frame rails don't rise as high over the rear end, so the bed floor sits lower. The side shape are similar to the 1955 (2nd Ser)-59 Chevy trucks.
The top of the bed sides (where the stake pockets would be) angle at the top on 1947-53's. The bed sides are flat on the 54-55 (1st Ser.). |
#5 | |
correct
Yes, you'll loose some bed depth. I've had a few customers that have ordered our 47-53 chassis that have 54-55(1st Ser.) so that there is more suspension clearance for a lower stance and just raised the bed floor.
#8 | |
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
_Ogre, I think like you.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
I actually like to raise the bed a couple of inches and raise the running boards to match. The cab kind of over powers the bed on the AD trucks. When you raise it up a bit it makes the cab not look so big from the back.
Jeff |
#12 | |
Albeit mines a bit of an exception. Trying to fab a bed to a 1 ton frame. But I think it looks pretty good. Please bear in mind that the bed is just sitting on the frame, (no mounting blocks) and it has about a 2.5 inch rake on it. But I think it'll look good when it's finished. |
