Old 06-22-2003, 04:50 PM   #1
Daves72'GMC
Question rhino lining inside bottom of the doors?
Should I have the inside bottoms of my doors Rhino lined where the holes are to let the water out? MY body man says it helps when the water goes inside the doors and goes through the holes the bottom of the doors and theydon't get wet and helps prevent rust. any suggestions ? Thanks everyone.
Daves72'GMC is offline   Reply With Quote
Old 06-22-2003, 06:32 PM   #2
Randy70C-10
Randy70C-10's Avatar
Interesting, I thought up that idea over a year ago, thought I was the only one. I'm sure that it would work, just make sure that you re-drill the drain holes.
Randy70C-10 is offline   Reply With Quote
Old 06-22-2003, 09:59 PM   #3
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
i was thinkin gof having the floor of my cab lined once i have all the new patches welded in. then put the carpet over it. then i don't have to worry about rust on the floor anomore. maybe i will have the inner doors done as well. and how about the cowl as well?
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 06-22-2003, 10:09 PM   #4
1969 GMC
1969 GMC's Avatar
I too would liek to do that...whenever I do all the bodywork to my cab, I'd like to just spray rhino liner (or similar) on the floor, firewall, kickpanels, and the back wall, up to the line under the window. Then when it gets dirty, just hose it out.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 06-22-2003, 10:46 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I was thinking of doing the same, but with the POR15.
Old 06-22-2003, 10:59 PM   #6
mtdave2
newly minted old timer
mtdave2's Avatar
i spraied some of that rubber bed liner stuff on the underside of the doors... working well!
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 06-23-2003, 12:06 AM   #7
XXL
Señor Member
XXL's Avatar
Any of the catalyzed elastomeric polyurethane products (like Rhino) will be expensive... especially if your local dealer/installer is a production shop that's just used to knocking out beds. Also, it can get pretty heavy.
Just some random thoughts.
Kenneth
XXL is offline   Reply With Quote
Old 06-23-2003, 05:46 AM   #8
Lippyp
English Chevy Owner
Lippyp's Avatar
Before the winter gets here again I intend to rustproof my truck with one of the many treatments available here in the UK (Waxoyl, Dinitrol) These are basically a waxlike substance that you inject into all the cavities (rockers, door pillars etc) it has good creeping abilities and even self repairs if it gets a small scratch as it doesn't set fully hard. It's waterproof and also airproff so stops rust pretty well. There are also variants for spraying the underside of the truck and chassis with, available in both clear and black. It's a horrible messy job to do but worth it in the long term (remember to drive the truck onto a plastic sheet or you get a rustproofed nice slippy drive!). Not sure if similar products are available in the U.S.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 06-23-2003, 02:02 PM   #9
mocwon
Keep On Truckin'
mocwon's Avatar
I used rubberized under coating in my car doors and on the floor (before underlayment). It works great, is cheap and easy to apply. I used urethane for many of the seams like when the outer wheel house attaches to the quarters. This stuff is great but somewhat expensive. As mentioned, open up the holes in the bottom after you cover them.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-23-2003, 02:10 PM   #10
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
I used the rubberized undercoating also...when I did the inner door bottom and outer skin... I sprayed rustproofing stuff first then then undercoating.
Suicide-D is offline   Reply With Quote
