Old 04-23-2013, 04:14 PM   #1
lil_sahara450r
P/S question for Captainfab
Hey Capt!
I was going to PM you but I figured that I would post this question on the boards so others could see. Here it is!
I bought the power steering bracket and tube/flange kit from you, I have a brand new steering box, and a power steering pump and the necessary brackets for a V8. Now I need hoses. While looking on Rockauto for the hoses I found that there are many different hoses available, with different bends and such. Just need to know which set to order to make it look right.
Let us know which ones you prefer!
BTW guys, Thought I'd let ya know that Rockauto has power steering gear boxes for this conversion for cheap. I got a Lares brand remaned unit for $108 plus shipping (and then 5% off of that with a readily available coupon code). These are nice units with a lifetime warrenty and the company seems to focus on the collector car market.
Lares
Part #: 1074
Thanks!!!!
'66 SWB BBW Custom cab factory A/C
OEM roller 350/TH400
C-notched and bagged
Frame off in progress!
'69 Camaro Original 327 4 speed - completed
lil_sahara450r is offline   Reply With Quote
Old 04-24-2013, 12:16 AM   #2
Captainfab
60-66 Nut
Re: P/S question for Captainfab
It's been over 10 years since I have done a PS conversion, and I just used a pressure hose I had from a donor.
What hose to use is going to partially going to depend on what engine you have. If a small block or big block, do you have a short water pump like should be in these trucks, or a long water pump? If you have a short water pump, a hose for a '68-'72 truck should fit reasonable well. As an alternative to a factory hose, you can also have a custom hydraulic hose made up for the pressure hose. The return hose, can have just hose clamps on each end. Although you do need to use a hose made for use with oil/PS fluid.
Old 04-24-2013, 12:26 AM   #3
cb1965
cb1965's Avatar
I used a pump and hoses for a '72 c10. Worked out great.
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 04-24-2013, 10:18 AM   #4
Snowbound
Snowbound's Avatar
I used a serpentine set up, but the PS pump is low on the driver side. I got a stock hose for a 75 C10 and it fit pretty well. I can dig up the part number if you want.
Brian
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 04-24-2013, 11:56 AM   #5
slepysal
slepysal's Avatar
I used 1972 c10 hoses on mine. Be sure you get the right hose becuse the later ones had an O-ring type fitting
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-24-2013, 03:11 PM   #6
lil_sahara450r
Thanks alot guys! What I did was look up hoses for a 75 C10 and I will have to pick which ones I want from there. I knew the hoses changed around 1980 from the flared to the o-ring style. Theres just so many different part numbers
Old 04-24-2013, 03:38 PM   #7
MikeN
MikeN's Avatar
I had a lot of trouble with hoses on my conversion. The return line is no problem. It's not under pressure, and at the pump end of the return line all you have is a hose barb and a hose secured with a hose clamp anyway.
On the pressure side, I tried a lot of different hoses from different year model trucks before I ended up fabricating a steel braided hose with AN fittings. The braided hose is working fine so far, and I drive my truck every day
MikeN is offline   Reply With Quote
Old 04-24-2013, 03:51 PM   #8
slepysal
slepysal's Avatar
the ac delco # I used is 36-355240 if that helps any
Old 04-25-2013, 03:12 PM   #9
lil_sahara450r
I'm gonna order this one and see how it works out. Thanks alot slepysal
Old 04-25-2013, 03:14 PM   #10
lil_sahara450r
In case I cant get one to fit, would you point me in the right direction as to where to get the parts to do a custom hose like what you have?
Old 04-26-2013, 10:14 AM   #11
MikeN
MikeN's Avatar
When i get home tonight I'll list the parts. Making braided steel hoses is not too hard, but if you've never done it you sort of have to learn the technique. I learned to make them working on my uncle's race cars, so I'm comfortable with it.
It's also kind of expensive if you don't have some left over hose and fittings laying around.
Old 04-26-2013, 11:15 AM   #12
lil_sahara450r
That sounds pretty good. I make hoses a lot at work so it shouldn't be a big deal for me. Sure do appreciate all the help guys
