425hp409
![]() Join Date: Oct 2008
WTB: 71-72 rear differential
I need a 71-72 1/2 ton rear differential housing, bare will be OK.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
#2 | |
Eat, Sleep, Drive a Chevy
Re: WTB: 71-72 rear differential
I may know where there is a housing, I am checking now
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
![]() Join Date: Aug 2012
1 1/2 plus wider. I have one I will give ya if you are doing a 68, but it comes with a long travel from florida.
i got a one from a 70
build thread - 1972 C/10 "Ethyl" 1974 C/10 " Paw Paw" C/10 Club Louisiana ![]() instagram - @esso_c10 @projectpawpaw |
#5 | |
425hp409
Hmmm, you know if you change housings to reuse the 72 axles you will have to have some one set up the gears, you can not just swap the center section without checking pinion depth and backlash, would also require new crush sleeve and seals.
The best option is to get some 5 lug axles from Moser engineering that will fit the 68 rear housing. they will run you about 250.00 then sell the 72 axles
#7 | |
425hp409
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette Last edited by 425HP409; 04-24-2013 at 12:18 AM. |
Let me know if you want to sell the 72 axles. They should work in my 70 rear end.
Posted via Mobile Device |
#9 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
![]() Join Date: Jan 2011
you're looking for 30 1/2" long from the mounting flange to the end of the splines (early rear end) The later ones are 31 5/16" long from this same measurement.
I agree, I'd do the early setup, you can run less backspacing too (your wheels will appear wider) Your early housing is highly desirable too, especially on the bagged trucks simply because it's a bit narrower. Your 71-72 5lug axles will be an easy sale.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
425hp409
I found the early 30.5" 5 lug axles from my differential parts supplier in Dallas for under $150 each. Yahoo.....
#12 | |
425hp409
