What tank will fit??
Re: What tank will fit??
Blazer tank as I hear it is a popular swap.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
A K5 Blazer tank??
Posted via Mobile Device |
31 gallon blazer tank will be a tight fit on a SWB. If you got the smaller one (25 gallons?) it'll fit good. I used my stock crossmembers and welded some angle iron onto them to hold my burban tank. The biggest problem you'll run into is figuring out where to mount the filler.
Read this how-to, it pretty much sums it up and you can figure out the rest: http://www.captkaoscustoms.com/blazertank.html |
I'm going to run it up through the bed if I can, I'll check it out thanks alot
| Bookmarks |
