Old 04-23-2013, 09:39 PM   #1
Sloan66
Power Brake Upgrade?
Installing a factory unit onto a 71. First question is there any difference between the manual brake pedal and the power one? When I hooked up the rod to the pedal it moved the brake pedal a lot closer to the floor. I adjusted the rod out, but it still does not hit the bump stop like it did with manual brakes.
Is this normal?
The rod, and brakets all came off a 72
One other thing my truck has a clutch if that makes any difference.
Sloan66 is offline   Reply With Quote
