Old 04-24-2013, 09:05 AM   #1
themb2g
mafs to speed density
I'm looking to cut out the MAFS and go with a speed density set up. Has anyone done this? What changes fo you need to make other than reprogramming the computer?
Check out my build: 1972 LQ4 Swap
http://67-72chevytrucks.com/vboard/s...=1#post5427693
themb2g is offline   Reply With Quote
Old 04-24-2013, 09:13 AM   #2
classic70
classic70's Avatar
Re: mafs to speed density
As far as I know just reprogram the pcm.
classic70 is offline   Reply With Quote
Old 04-24-2013, 09:13 AM   #3
Custom 68
Custom 68's Avatar
it depends, mine is turbo so I opted to get rid of my MAF. In general it would have worked even in my setup but I had a bend in my piping right before the sensor and it would not read correctly. I also had the chance to go to a 2 bar system, now with FI I can read and control the computer when in boost.
If you are not FI then the change over is easy but I will ask why? I ran mine with mine originally for years with it and it was no problems. You can just disable it in the tune then your are running SD only, you will need to add a air intake temp sensor and wire it into your harness to the MAF.
Anyway unless you are having problems or just dont like the looks of the MAF and cant get it to fit right I would leave it.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-24-2013, 09:21 AM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
I switch over to speed density in all my LS swaps, not just my turbocharged ones. Personal preference I guess, but they all run great. Plus the clean look is nice. Calibrating the MAF if you change any of your intake plumbing is kind of a PITA also.
Like Custom 68 said, you'll need to wire in an IAT sensor, and make a few changes in the tune. Best to run a 2/3 bar OS (in EFI Live), that way when the MAF is failed (to force speed density) you get both your low and high spark maps.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 04-25-2013, 10:16 PM   #5
themb2g
Where does the air intake sensor go and do you have a picture of one set up?
Old 04-25-2013, 11:17 PM   #6
Custom 68
Custom 68's Avatar
I will need to snap a picture but I just drilled a hole in my intake tube and installed it there.
Dave
Old 04-26-2013, 10:51 AM   #7
themb2g
Thanks, that would be great.
Old 04-26-2013, 03:52 PM   #8
prostreet1967
prostreet1967's Avatar
i have seen where someone removed the purge valve on truck intake and tapped hole and threaded IAT in there.
prostreet1967 is offline   Reply With Quote
Old 04-26-2013, 10:11 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Usually it would go in the intake track; I imagine that doing it in the manifold might be less accurate, from both air turbulence and an increase in temperature from using in-manifold air.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-28-2013, 10:12 AM   #10
1969x11
^^^^This...works like a champ.
1969x11 is offline   Reply With Quote
Old 04-28-2013, 12:17 PM   #11
themb2g
I was talking to the Spectre Tech the other day and he mentioned to put it 8" to 10" from the TB. I would love to run it in the Purge Solenoid spot though. Would the inaccurate readings lead to poor efficiency/less power? What is the negative part of the inaccurate readings?
Old 04-28-2013, 12:17 PM   #12
Super73
Super73's Avatar
I do it with most my customers cars and my personal ones as well.
I have a 1 bar SD tune from hp tuners that allows you to use both high and low spark tables. If you force a fail with out the custom OS you are limited to the low spark table.
But simply put the process looks like this for drive by cable (drive by wire is much different).
Disconnect MAF
If vette or truck harness, rewire an AIT (99-02 fbody harness had then seperate)
In the tune:
Copy high spark table to low table
Change Power enrichment EQ to 1.14 in all cells (this will command 12.9 @ WOT)
Change enrichment rate to the max (4 in most cases)
Disable Cat Over Temp if you don't have cats it can screw with fueling at WOT
Disable Decel Fuel Cut Off
Disable Ltrims and bump their on threshold to 280*
Under engine diagnostics, change all MAF codes to no SES light and Fail on 2nd event
Now you can clean up the VE table to get the proper AFR.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-28-2013, 12:22 PM   #13
themb2g
Disconnect MAF
In the tune:
Thank you! Do you have a picture of what the sensor looks like? I have two separate harness's, one from an 02.
Old 04-28-2013, 11:55 PM   #14
Super73
Super73's Avatar
02 fbody?
Old 04-29-2013, 10:48 AM   #15
Wasted Income
Boosted Member
Not true. I've found that I get much better / stable IAT readings with the sensor in the intake (at the EGR port on a truck intake for instance).
The plastic will not heat soak like an aluminum tube will, and you are getting the ACTUAL temp of the air in the intake, which is what matters...not what the air temp is a foot or more away from the TB.
I've done it that way on several setups, works great, and cleans up the wiring a bit as well.
Turbo diesel
Old 04-29-2013, 01:05 PM   #16
themb2g
Super 73 I have two harnesses. One from an 02 Avalanche and the other out of a 07 express 3500.
Old 04-29-2013, 01:52 PM   #17
Wasted Income
Boosted Member
Those are two totally different harnesses, with two totally different purposes.
The 02 harness is a DBC harness, and has a provision for an IAC valve.
The 07 harness is a DBW harness and does not have the IAC plug, since they use the TB for IAC.
They also require different PCMs.
Turbo diesel
Old 04-30-2013, 07:39 PM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
How much do you think the tube actually heat soaks? I see iat (off my scangauge) at anywhere from 95 to 117 the past couple days, with it in the high 50's low 60's outside.
Old 05-01-2013, 02:53 AM   #19
Wasted Income
Boosted Member
With my turbo setups, I've seen them heatsoak a lot...that will happen with 200+ degree air coming out of the turbo.
N/A still heatsoaks, but not as much.
Turbo diesel
Old 05-01-2013, 10:09 AM   #20
jorgensensc
jorgensensc's Avatar
So if there are advantages to running speed density, what are the disadvantages? Obviously GM decided to go with MAF over Speed density for some reason.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-01-2013, 11:16 AM   #21
Wasted Income
Boosted Member
The biggest disadvantage in my opinion is that once the tune is dialed in, if you change anything (air filter type or routing, exhaust, cam, heads, etc) it will need a retune of the VE table.
The MAF lets you get away with more changes by compensating (within reason) for these changes.
Here's some reading for you.
http://www.pcmforless.com/index.php?...ning&Itemid=56
Turbo diesel
Old 05-01-2013, 01:43 PM   #22
faribran
so, what are most using? MAF or Speed Dens?
faribran is offline   Reply With Quote
Old 05-01-2013, 03:11 PM   #23
Custom 68
Custom 68's Avatar
if I were to guess I would say MAFS since it is factory on most of these engines. If they are turbo or other FI I would say SD.
Like said above getting rid of the MAF does look nicer and might be easier for fitment.
Dave
Old 05-01-2013, 06:02 PM   #24
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I also weigh in, that MAF is nice when you do long road trips through multiple types of drastically different temp and density air, technically giving you the most "accurate" tables for the input its given.
From what I glean from speaking with members here and on ls1tech and yellow bullet, this is nice for fuel economy and cold start ups etc, but has little noticeable difference under most people's use. SD will be able to "make" more power.
Wasted- you had me staring at the gauges as to what my intake temps were all yesterday.
Old 05-01-2013, 08:50 PM   #25
Jon01
Jon01's Avatar
You guys are getting tied up in semantics.
As long as the tune has the appropriate adjustments to IAT timing tables you'll be fine.
I've only done 1 full on SD tune, 4-5 years ago. It was a 427" LSx, solid roller, ported AFR's, etc...basically a max effort N/A motor.
Otherwise everything gets a MAF. It's failed to tune the VE table but once that's completed it's re-enabled and tuned.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
