04-24-2013, 09:45 AM | #1 |
what steel piping can be used in place of flexible air line on airide
I have a delema I have a tight spot on my trucks air setup on the front of my truck. Can I use metal plumbing pipe from the airbag to the side of the frame a total if 10inches or is the airpressure to much for the pipe. Copper line to soft?
Posted via Mobile Device |
04-24-2013, 10:53 AM | #2 |
Re: what steel piping can be used in place of flexible air line on airide
There was a post about this before but can't find it now. Someone used some metal tubing from summit another used copper tubing. I believe the copper drawbacks was after vibration it hardened n cracked after awhile. Maybe someone can locate that post for you.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
