Old 04-24-2013, 01:50 PM   #1
chevy72blu
chevy72blu's Avatar
Upper and lower bushings are rubber. Is my front end a 73-87?
My 72' had disk brakes installed by the PO and I've always had a suspicion that they were out of a 73-87 (had to grind and clearance for direct fit headers, etc).
Is there any sure fire way to tell what it is out of? The upper and lower bushings are rubber and I believe they are supposed to be steel on a 72.
Lastly, my steering box needs to be replaced. Is this a 73-87 part specific to the front end?
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-24-2013, 07:20 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Upper and lower bushings are rubber. Is my front end a 73-87?
If the bushing has a big nut and a washer, then 73-87
If the bushing looks like a giant bolt head with a grease zerk in the middle of the head, they're 72 and earlier parts.
Old 04-27-2013, 01:46 AM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
You have 73+ upper control arms... like TX said ... not sure if it was a whole crossmember swap... didn't look that close...
Steering box will bolt onto the frame from 69-87 (or 91 on Suburban / Blazer)... There are, however, a few differences... The line connections chananged from SAE to metric in the 80's... They went to variable ratio in the later 70's...
I needed a 2WD box for my crossover steering on the Blazer. I purchased -AN fittings for the steering box and I had to swap the rag joint because the slpines didnt match my 72 steering shaft... The box came out of a late 80's C30 truck....
Rich
1972 K5 Blazer CST Click HERE
Old 05-01-2013, 01:09 PM   #4
chevy72blu
chevy72blu's Avatar
Thank you guys for the info.
Are sway bars different for the 73+ and which one should I go with? I plan on just finding one of out a 73-87 burb in a yard, but ECE lists them for 67-72. The frames should be basically identical so I want a 73-87 bar and mounts, correct?
RIP EastSideLowLife
Old 05-01-2013, 01:35 PM   #5
Tx Firefighter
Read the sway bar FAQ. I should answer most all of your sway bar questions in there.
