Old 04-24-2013, 03:28 PM   #1
1970 C10 MJW
1970 C10 MJW's Avatar
steering column removal
how the heck do i get the steering column out? i already have the brackets on the inside that hold it to the dash off, but I cant figure out where to take it apart at in the engine bay... pictures are helpful!
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 04-24-2013, 03:54 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: steering column removal
Don't have pics here at work but you need to unbolt the gasket from inside of the firewall and outside the the firewall you'll find a bracket undo the nuts from the studs and drop the clamp. Hey an avitar finally
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-24-2013, 05:08 PM   #3
1970 C10 MJW
which bracket are we talking bout outside the firewall?
Old 04-25-2013, 06:37 PM   #4
luvbowties
luvbowties's Avatar
Smile Re: steering column removal
Take shaft loose at the rag joint: remove the coupling nut/bolt and work shaft out of rag joint. Remove steer. wheel. Steering shaft should slide up/thru the in-cab remaining column. You'll begin to think it's not gonna clear, but just keep sliding. When shaft is out, column should then come right out. (Some people have told me they remove shaft the other direction, by jacking up front end really high to allow it room to clear the floor. I've never tried it, tho'.)
HTH,
Sam
luvbowties is offline   Reply With Quote
Old 04-26-2013, 10:42 AM   #5
1970 C10 MJW
interesting... so the shaft doesnt have any points of separation???
Old 04-26-2013, 12:13 PM   #6
Lattimer
Lattimer's Avatar
Only if its tilt wheel. Otherwise, the shaft is straight through the column to the first joint at the collapsible shaft.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 04-26-2013, 12:20 PM   #7
Lattimer
Lattimer's Avatar
If you are pulling the whole column:
Once you have the column loose under the dash, you unbolt the plate from the firewall and the column, then you unbolt the joint at the collapsible shaft.
Shawn
Old 12-04-2014, 04:01 PM   #8
dynodave
I was replacing my steering column on 68 Stepside with tilt steering column from Classic performance parts.. It is supposed to be a model specific kit, but the installation starts off with indicating a 1" DD u-joint for the column end to the steering shaft (cutting it?). However the CPP specs guy said the new column shouold attach directly to the steering shaft at the joint of the collapsible shaft. Does anyone have any experience with this? Does the steering shaft come apart at this collapsible joint?
dynodave is offline   Reply With Quote
Old 12-04-2014, 04:10 PM   #9
ripper70
ripper70's Avatar
It does come apart but i reused collapsible shaft cut that end off and used a Billet u joint at that end.
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline   Reply With Quote
Old 12-04-2014, 04:31 PM   #10
dynodave
If the steering shaft does come apart at the collapsible joint & supposedly bolts direct to the replacement column, why would you cut it off and use the billet u-joint? That's another $50.00 at CPP (u-joint)?
Old 12-04-2014, 04:52 PM   #11
ripper70
ripper70's Avatar
It comes apart and looks like a t at the end. The other side comes off the splined steering column. They might be saying your new columns splined shaft will fit the female splined on your factory joint. My factory joint was to big so i cut it off and bought a u joint.
1970 K20
1967 Blown Stepside
1989 Jeep Cherokee
1995 S-10
Old 12-04-2014, 04:54 PM   #12
ripper70
ripper70's Avatar
Unbolt the joint off the column and pull it off. Count the splines on your new column and count the splines in your joint. If there the same your golden.
1970 K20
1967 Blown Stepside
1989 Jeep Cherokee
1995 S-10
Old 12-04-2014, 05:45 PM   #13
dynodave
OK, here we go...Thanks for the info. Looks like you used the same chrome steering column replacement in your resto. Tilt?
Old 12-04-2014, 06:55 PM   #14
ripper70
ripper70's Avatar
Its a flaming river tilt
1970 K20
1967 Blown Stepside
1989 Jeep Cherokee
1995 S-10
