Old 04-24-2013, 04:25 PM   #1
forestb
forestb's Avatar
is it worth it
My inner fenders are in good shape except they have had a number of holes drilled in them over the years. O found a pair of old ones at the wrecking yard that are in just as good of shape but have no holes. Would it be worth while to pull those of the truck at the yard or just fill the holes in the fenders I already have? (the holes are all a 1/4 inch or less)
forestb is offline   Reply With Quote
Old 04-24-2013, 04:29 PM   #2
Budman56
Budman56's Avatar
Re: is it worth it
I would say fill the ones you have as long as you fill comfortable doing so.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 04-24-2013, 05:02 PM   #3
da_bears_da1
Re: is it worth it
X2
As long as you can weld and grind I would just do that. Never know what you will find once you pull the ones from the junk yard. Could end up pulling them and then go back to your and filling, IMHO.
Jeff
Simplify Life!
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=566533
da_bears_da1 is offline   Reply With Quote
Old 04-24-2013, 05:03 PM   #4
forestb
forestb's Avatar
Re: is it worth it
I can't weld or do body work. It would be something that I would have get done when I get the rest of the body work done. The new inner fenders I could install my self.
Old 04-24-2013, 06:44 PM   #5
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: is it worth it
You may have answered your own question..
Even if a body shop fills them, they will be welded and maybe a little body filler in needed to finish it. Your labor to swap them out is probably cheaper than the bodyman's price to fill them.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-24-2013, 07:54 PM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
Re: is it worth it
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
